Megablade Seats
Hi,
I'm new to the forum and have recently purchased a 2001 Megablade which I intend to use for track days. The previous owner had fitted two very nice Triton lowside seats but I'm slightly wider than the previous owner and would like to replace them as they are very tight on me.
Has anyone fitted fibre glass seats from Kit Parts Direct? The dimensions on the Kit Parts Direct web site are slightly wider than the Triton seats?
thanks, Hadrian
Hello there, I can't help you out with your question but I thought I'd say welcome, I too have just bought a 2001 megablade so there may be other questions I can help with, plenty helpful peeps on here I'm sure someone can help!
Dave
Not sure you'll get seats that are 445mm wide in a wide body Westfield - definitely not if you have interior side panels fitted. You can always try JK N4942 seats that are 42.5 cm wide which are pretty much the widest most people fit - at least a bit wider than the Triton 412mm wide (370mm internal base width) that you have. See http://www.jkcomposites.com/7s-page.html
Thanks for the welcome and advice
