John Loudon - Sponsorship Liaison Posted January 25, 2012 Posted January 25, 2012 I'm puzzeled by all the latest ads on TV for Saniflow systems - fit a bog in your cellar or attic or anywhere. Simple water connections are all thats required apparently. If thats the case, where does all the crap end up? Do you have to empty it occassionally? Just curious as I'm not interested in buying one. I've looked on their website and the info on how they work seems vague Quote
zvezdochka Posted January 25, 2012 Posted January 25, 2012 Saniflow has a motor driven macerator to smash the crud and then pumps the slurry. advantage is you can use a 2 inch pipe instead of 4 inch for waste. Quote
KugaWestie Posted January 25, 2012 Posted January 25, 2012 You can actually run the macerated waste in a 22mm overflow pipe, it is pumped under pressure and then either ends up in a manhole or gets connected into the soil and vent pipe Quote
Hammy Posted January 25, 2012 Posted January 25, 2012 The do work ok , but can be very exciting when they go wrong Quote
Dibby Posted January 25, 2012 Posted January 25, 2012 It's for if your thunderbox is below the sewer level and won't gravitate. It pumps up and all the crap ends up in the sewer system. Maceration is no longer allowed in the water industry, don't know how long private customers will be able to get away with it Quote
bhouse Posted January 25, 2012 Posted January 25, 2012 The do work ok , but can be very exciting when they go wrong They're also very powerful. Did you know they can project the 'macerated waste' up to 5 metres with a spread of 2.5 metres if an incorrectly fitted output knuckle fails... Quote
Mark (smokey mow) Posted January 25, 2012 Posted January 25, 2012 The do work ok , but can be very exciting when they go wrong They can also be very noisey and the motor runs after the flush for a while so are not really suited for use quietly in the middle of the night unless you want to wake the wife. Quote
Terry Everall Posted January 25, 2012 Posted January 25, 2012 I dont like em and they are a bag o ****e Quote
John Loudon - Sponsorship Liaison Posted January 25, 2012 Author Posted January 25, 2012 Hmmm - so not as easy peasy as made out. Still needs connection to sewer which isnt mentioned Quote
perksy Posted January 25, 2012 Posted January 25, 2012 They can be very noisy and when they block it can be great fun, Don't ask how i know Also check that the one you choose can pump the s**t as far as you need it to We install/use them at work but only as a last resort... Quote
Jumpy07 Posted January 25, 2012 Posted January 25, 2012 I have a Grundfos one.. very quiet and doesent run very long after a flush.. plumber recommend it over the Saniflo one.... Word of caution.. wet wipes kill them.. not very nice to dismantle and remove... Craig Quote
peterg Posted January 25, 2012 Posted January 25, 2012 Hmmm - so not as easy peasy as made out. Still needs connection to sewer which isnt mentioned P'raps they thought it was too bleeding obvious to most intelligent people.... Quote
John Loudon - Sponsorship Liaison Posted January 25, 2012 Author Posted January 25, 2012 P'raps they thought it was too bleeding obvious to most intelligent people.... Nope - they clearly show only water supply pipes in their working diagrams Quote
peterg Posted January 25, 2012 Posted January 25, 2012 Seems fairly clear on their website http://www.saniflo.co.uk/homeowners/sfa-product-line/saniflo-product-description/ The Saniflo macerator pump unit fits unobtrusively behind the WC.You may choose any make or colour of WC suite (BS EN 33 or 37 Horizontal Outlet) you want to suit your decorative scheme. When the WC is flushed the unit automatically activates to pump waste horizontally to a remote soil pipe up to 50 metres away. Saniflo will also discharge vertically up to 4 metres maximum, or a lesser combination of vertical and horizontal pipe run. Quote
