GoPro Motorsport HD Camera
Just a quick heads up,
I have just ordered myself a GoPro Motorposrt for trackdays from amazon, they have them on offer at the min for £154 new. Bargain!
Clicky Clicky
no longer available at that price now £175 still cheap though
:o how strange! Checked the link just before posting and they were still at 154. They must be on to me haha.
They are still at that price but you just have to look a bit further!
Yep, mark 2 version was launched before Christmas, so some great offers around on the original at the moment.
great camera heres a couple of vids to prove how good they are even in the rain!
Brilliant camera, only downside is the sound!
True, the Mark 2 includes a mic input in the many improvements. Not had a chance to test yet. TBH though, while they get used a lot for pro video - you see them all the time, just creeping into shot! They'd typically be edited in with either a backing track "covering" the audio up a bit, or if serious high quality sound is needed, a sepperate audio recorder is used.
I've got a little self powere mic on order though, so going to have a go and see what it's like.
For those handy with a soldering iron, the GoPro HD 1080 models with accessory bus, can have a lead made up so that you can hook a extra mic in via the bus.
Hmm, guess I have to take a look at the Mark 2 then!
Cant you post up a film with the new camer to "hear" the differnce? ;)
the original hd's are available new for 120 with free postage from the states via ebay !!
I'd be interested to hear the Audio with an external mic on the Hero2 also when you make a video.
I've already got 2 Gopro's (a 960 and a 1080HD) which I use in a 3-camera set-up with a bullet cam and external mic, but I've been thinking of upgrading to the new one in the hope of getting some better sound recording for single camera use.
Was checking the Go-Pro webbsite and could not see if the protective shell has an opening for the external mic. I cant see that.
So how are you going to use that external mic? Drill a hole in to the casing so you can plug it  in?
I did thi k about getting a skeleton case, but then the pas few times I've been out with the camera on its got a drenching from the vast amount of water R1R's seem to be able to suck out of innocent looking little puddles  :oops:  :D
So instead, I've decided to drill the standard sealed case. (will try and get an O ring or something to help seal the plug where it goes through  :t-up:
I'm just going to try an Audio Technica (self powered) Lavalier condenser mic and see how that goes. The idea is to put the mic in the boot box first off, as that seems to work for others.
Currently with the built in mic, I get OK ish sound with the camera on the nosecone looking back, though the wind noise is a little dominant. With the camera on the rear wing, the sounds poor, mainly wind and rattle from the camera/case/mount combo itself. (a known weak spot). With only a little induction noise and almost no exhaust.
Picture quality so far is fantastic though, even just "testing settings". Quite staggering how much better it copes with poor light than the earlier model. (though obviously at the expense of some picture noise).
Will post some links up soon as I've had a chance to try the mic. (should have it Thursday or Friday).
Just need the remote/viewer software then, and I'll be good to go. Hopefully that should be launched in Feb, subject I guess, to App Store approval. (Remote Wi Fi control and viewing via an iPhone).
