Paul Ash Posted December 28, 2011 Posted December 28, 2011 I have for sale my C20XE bottom end . Spec. C20Xe Block Bores 86.5mm Std C20XE Crank SBD 86.5mm Omega forged / pocketed pistons Un-branded Forged Rods / ARP 2000 bolts (similar to Eagle Rods) ACL Duraglide Bearings SBD Head oil feed restrictor fitted to block Water pump (Crank was balanced/Revs to 8500rpm on current set up) Currently still in my car but will be stripped out in the next few days, so if you want to hear it running be quick ! Has done approx 7000 miles since build + 3 Trackdays. £600 + Delivery Location Nr gatwick May split, but would prefer to sell complete
Paul Ash Posted December 29, 2011 Author Posted December 29, 2011 About 11.7:1 with STD Head. If Piston machined flat about 11.0:1 with STD Head With head skimmed could get up to 12.80:1 depending on Cams being used.
