Hammy Posted December 26, 2011 Posted December 26, 2011 My som has bought me an automatic welding mask, I've not tried it yet but putting it on my head and switching on the view still seems quite dark ( not done any welding this is looking at the telly) . Is this normal and do you therefore normally have to have the workpiece well lit ? Quote
SteveD Posted December 26, 2011 Posted December 26, 2011 depends on the make etc ,some are crap my findings with them are you get what you pay for with auto masks but should be quite clear ,i dont use them personally we do have a couple but i just prefer a normal mask ,i use to use a auto mask but after getting a few flashes when welding on higher outputs stopped using them Quote
Terry Everall Posted December 26, 2011 Posted December 26, 2011 Steve You been caught out flashing again wuv? Quote
ianstewartshouse Posted December 26, 2011 Posted December 26, 2011 I've just bought a 'cheap' on for 40 quid and it works a treat. As Steve says mine is clear when i look through it before striking an arc. I think this is my one http://www.amazon.co.uk/dp....34BHBUO Quote
ianstewartshouse Posted December 26, 2011 Posted December 26, 2011 Silly question but might it be that it needs to charge up the battery before use? Some of them use the solar panel to charge the battery aswell and it may need charged Only a thought. What make is it? Ian Quote
Gromit Posted December 26, 2011 Posted December 26, 2011 Mine`s quite clear when it`s not active, its like looking through some mildly tinted sunglasses. I find, you still need a fair bit of light to work by though. Quote
Hammy Posted December 26, 2011 Author Posted December 26, 2011 I've just bought a 'cheap' on for 40 quid and it works a treat. As Steve says mine is clear when i look through it before striking an arc.I think this is my one http://www.amazon.co.uk/dp....34BHBUO Exactly the same model as mine ian - i would not describe mine as almost clear, it's very dark compare with say sunglasses. Ivetried two sets of batteries. Quote
ianstewartshouse Posted December 27, 2011 Posted December 27, 2011 Maybe my recollection is not good, Im away with work and wont be back till 5th Jan so cant go out and look unfortunately Best way to find out is trying it with some welding. Ian Quote
SteveD Posted December 27, 2011 Posted December 27, 2011 Maybe my recollection is not good, Im away with work and wont be back till 5th Jan so cant go out and look unfortunately Best way to find out is trying it with some welding. Ian or so you dont get a flash ,try by sticking it on you noggin and looking at a bright ceiling light close up then looking away and back again Quote
Dave Eastwood (Gadgetman) - Club Chairman Posted December 27, 2011 Posted December 27, 2011 I don't know about the Draper's, but my Sif jobbie is light enough to see through OK under a few flourescent lights or outdoors etc. the speed/degree of darkening can also be adjusted though. Different grades of filter are available too. Quote
leeswesty Posted December 27, 2011 Posted December 27, 2011 Has it got any settings on all the ones we had when i was welding and the one i have at home you can set from grade 9 to 12 so it light or darker but i have had no problems when using one. Quote
Hammy Posted December 27, 2011 Author Posted December 27, 2011 Just checked it out with a new set of batteries -it works fine in sunlight outdoor but won't work off the batteries alone, the screen just remains very dark and doesn't go any darker when welding - so I guess its faulty, duff etc ( bad connection somewhere?) ; now the fun begins in returning to Amazon... thx for the words of help Quote
pete g Posted December 27, 2011 Posted December 27, 2011 i have a cheapy one and it works great it has battery indicator on the inside and adjustable darkness knob. just remember to remove batteries when not using.or they will leak.no on/off switch. my eyes get arch eye very easy and having had it a few times dont want it again, if i can help it. since using this type of mask i have had no mistake strike ups . because i can see what im welding with mask on,before and during welding. Quote
pete g Posted December 27, 2011 Posted December 27, 2011 Just checked it out with a new set of batteries -it works fine in sunlight outdoor but won't work off the batteries alone, the screen just remains very dark and doesn't go any darker when welding - so I guess its faulty, duff etc ( bad connection somewhere?) ; now the fun begins in returning to Amazon... thx for the words of help does it have battery indicator inside . mine has a green and red light to tell you its working ok Quote
Crash test dummy Posted December 27, 2011 Posted December 27, 2011 I've had mixed results with mine which is the same as Pete's I think. It works perfectly in that I've never had arc eye with it but I find that sometimes I can see the work well enough when welding and other times I can't. Not sure what the issue is, it just seems to be very inconsistent. For example if I'm welding 2 pieces together at 90deg I can see the weld perfectly on the inside join but not on the outside. I've tried playing with the settings but it makes little or no difference. I get a better, more consistent weld with a normal mask but the auto is so much more convenient that I do use it 90% if the time. Quote
