Posting photos from Flikr
OK i give up
I've seen the info for using gently hosting but have my photos on flikr and can post hyperlinks to the photos but when i try and attach them using the image button, so they appear in my post,  it tells me the link is the incorrect format, what am i doing wrong. How do i get the Flikr path to the correct format??
Puzzled!
Use photobucket.com - they give you every link under the sun
it so much easier than Filkr
make sure you have taken the tags off either side befpre you p[aste the link into the image add section on your post :)
Success but a bit of a faf!!
Thanks for the help
You've cracked it  :t-up:  :D
( :blush:  :oops: Posting pics that is, I'm sure the chassis is just fine  :laugh: )
:p  :p
Easy when you know how!!
