How heavy is a Westfield(2.0)
Looking for a 2.0 Westfield. How heavy is one typically and what can be done to reduce weight? I will want to keep a normal windscreen however!
How much do the bits you can take off weigh? (e.g heater components etc.)
......what can be done to reduce weight?
join a gym and go on a diet  ;)
Kinda need to know what the reasoning is.
It's not as simple a question as you might think.
Besides, it's not like any of them are especially overweight to start with......
it all depends how far you want to go...
people have been known to gun drill their half shafts!
a 2.0l westfield will normally be in the region of 550 - 650kg. If is outside of this norm then somebody has spent money either putting weight in (stereos - euuuch!;) or taking weight out.
to save weight the cheap way pull out stuff that you dont think is neccesary - carpets, windscreen, boot box, heater, weather protection, passenger.
after that it starts to get more exspensive - lightweight battery, brakes, wheels, carbon fibre bits, spendy instruments, new seats etc.
rember for virtually everything westfield make/sell there is somebody else making/selling a lighter equivalent (at a cost).
some engines are lighter than others as well.
OiOi
oh yeah, you did say how much does each component way  :devil:  :devil:
the numbers below are robbed from a website and nowt to do with me and are also from a cateringvan, but may give you an idea or two.
Weight of things 7 .
Wheels Wheel Tyre Wheel & tyre
Road
13x6 Minilight / 021R 185 60 13 @ 4mm 5.2 6.7 11.9
13x6 Minilight / 032R 185 60 13 @ 4mm 5.2 6.7 11.9
13x7 Minilight / 021R 205 60 13 @ 4mm 6.2 8 14.2
16x7 HPC wheels / Michelin 205 45 16 8 8.5 16.5
13x6 Revolution / Vrestein 185 60 13 @4.5mm 6 8 14
13x6 Revolution / Colway 185 60 13 @4mm 6 8.5 14.5
Race
13x6.5 Revolution / 7" 22 race wet 4.4 5.4 9.8
13x6.0 Revolution / 6" 21 race wet 4.35 4.4 8.75
13x6.5 R500 / Caterham Avon 20 7 13 slick (4mm) 3.2 4 7.2
13x8.5 Mad'in / Caterham Avon 20 9 13 slick (3mm) 4 4.4 8.4
13x7 Minilight / Caterham Avon 20 7 13 slick (4mm) 6.2 4.8 11
13x6 Minilight / Caterham Avon 20 7 13 slick (4mm) 5.2 4.8 10
Diverse
Air filter foam ITG inc backing plate 0.65
Air filters Piper cross ?
Alternator Valeo 45ah 3.5
ARB  front (Freestyle) 1.39
ARB front Caterham 3/4" 2.2
ARB rear (Caterham) 1.5
Axle Ford live (no oil) 50
Axle Ital live (no oil) 45
Battery (Banner wet lead acid Caterham supplied 300Ah cranking, 30Ah) 8
Battery holder for Banner battery in Stainless steel inc bolts 0.3
Battery (Hawker 25Ahr batt weight according to Raceparts) 9
Battery (Retop15) 400Ah cranking, 13Ah) 4.75
Battery bracket Redtop (homemade) 0.05
Bonnet 2.6
Boot floor inner (Ali) 0.45
Boot floor inner (Composite) 1
Boot floor shelf (honey combe) 1.7
Brake Calipers AP 4pot caliper and pads 2.46
Brake Calipers standard Sierra inc pads 3.5
Brake Calipers HiSpec 4 pot 2.45
Bake cooling (rear) ducts and hoses pair of 0.32
Brake disk HiSpec vented 4.25
Brake disk AP front vented 3.15
Brake disk standard Sierra 2.45
Brake pads 4 pot two of = one wheel 0.4
Cam cover front panel VX XE 0.7
Cam cover VX XE (backing plate, front cover and bolts 1.8
Camcover breather plate inc screws VX XE 0.24
Camsensor blanking plate VX XE   0.12
Camsensor inc plug for ECU 0.25
Car cover 0.4
Carburettor Weber DCOE pair inc Caterham inlet manifold 5.5
Carpet boot 1.5
Carpet footwells 0.72
Carpet Rear panel 0.8
Carpet tunnel 1.6
Clutch cable VX 0.3
Clutch assembly (Standard VX, cover and plate) 5
Clutch assembly (Standard Rover, cover 2.82kg and plate 0.61kg) 3.43
Clutch assembly (AP racing Rover, cover 2.22kg and plate 0.63kg) 2.85
Coil pack VX 3 pin 0.85
Coil pack VX 4 pin 0.9
Coil pack bracket 0.3
Crank ancillary pulley VX XE 1.55
Damper, rear Bilstein De dion long type 1.4
Damper, rear De dion Short type 1.3
Damper, rear De dion long type inc spring 3.3
Damper, front Bilstein 1.35
Damper Avo ali front 0.90
Damper Avo ali rear 0.93
Damper Avo ali rear inc spring 2.30
De dion ear 0.8
Diff Quaife LSD (no oil) 24
Diff Sierra 4x4 diff (inc oil) 21.5
Diff limited slip AP suretrack unit 5
Diff AP suretrack in diff complete 22
Engine 1700 XF (Carbs, clutch, ign plugs, oil, some water, starter etc steel wet sump) 112
Engine Rover K series 1.6 SS (as above) 105
Engine VXC Carbs, clutch, ign plugs, oil, some water, starter etc 133
Engine Zetec, 2.0L Carbs Clutch, plugs, oil, Throttle links etc 125
Exhaust shield 0.8
Exhaust, Caterham VX manifold 6
Exhaust, Caterham VX Race manifold 5.1
Exhaust, Caterham VX 5" can 5.5
Exhaust, VX Techcraft 6" can 5.85
FIA bar bolt on headrest 0.72
Fire Ext. 0.75kg handheld 1.15
Fire Ext. 2.25kg plumbed in, inc fitting kit 3.5
First aid kit 0.1
Flywheel VX standard 7.7
Flywheel VX (SBD lightened for standard clutch) 5.5
Fog or reversing light inc bolt 0.275
Foot pump plastic type 0.6
Fuel filler in boot inc overflow valve 0.3
Fuel filler (flush type inc hose) 0.6
Fuel hose 25bar / m 0.25
Fuel pressure regulator (high pressure inj type) 0.25
Fuel pressure regulator (low pressure carb type) 0.3
Fuel pump Facit interrupter type 0.5
Fuel tank ali inc injection pump (empty) 1
Fuel tank steel (empty) 3.3
Fuel tank crash protection kit 2.1
Gear knob Ali 0.14
Gear knob nylon (home made/hollowed out) 0.04
Gearbox T9 Quaife Semi heli internals & ali bellhousing 38
Gearbox T9 standard & alil bellhousing 40
gearboxT9 Airflow ali case and Quaife AC internals and ali bellhousing 33
Half side screen (homemade) 0.2
Hand cleaner pot of 0.4
Handbrake cover rubber 0.04
Headlamps pair 3.1
Heater inc water & control cable 2.7
Hood 2.5
Hood sticks 1.05
Horn (one of pair) 0.27
Hub Front wheel (ali) each 0.825
Hub Front wheel (cast iron) each 2.175
Hub rear De dion inc studs 3.2
Inertia switch rover type 0.08
Kneeling pad foam type 0.1
Map pocket (James Whiting) 0.12
Nose GRP 3
Number plate (front) 0.2
Number plate (rear) inc lamp 0.375
Oil 4ltrs 3.9
Oil and scavenge pump warning lights LED (high intensity) 0.005
Oil pressure lamp (21W bulb) 0.075
Propshaft Ital 4
Radiator ali road (water 1.65kgs) 2.9
Radiator ali race (water 2.15kgs) 3.8
Radiator VX standard 3.9
Rear light unit (Caterham standard issue) 0.55
Rear light innards (bulbs, plates and cable) 0.175
Rear light lens 0.11
Rear light block (rubber thing) 0.3
Rear light surround in Ali (replaced the above chunk of rubber) 0.05
Roll bar (FIA) exluding petty strut 9
Roll bar petty strut (FIA) 2.7
Roll Cage (Roadsports ) 10.5
Screen full Caterham style 3.9
Screen JPE acrylic type inc Spa F1 mirrors 1
Screen, aeros ali Caterham stanchion and F1 style mirrors 3.7
Seat belts 4 point belts (passenger) 1.9
Seat mount (for tillet Homemade) 0.15
Seat runners (Caterham) for one seat 1.6
Seat, (Tillet) carbon/kevlar 2.05
Seat, (Tillet) GRP 3.5
Seat, Leather new style (Caterham) inc headrest inc floor runners (Seat runners 1.6kg, Headrest 0.95kg, Seat squab 1.7kg, seat frame 3.4kg) 7.7
Seven Grille 0.2
Side impact bar (Roadsports) 2.4
Sidescreens Hi-vis (pair) inc standard wind mirrors 3.5
Sill protectors 0.5
Spares bag, bulbs, wire, fuses, multimeter, hose clips etc etc. 2.25
Spark plug cover VX  XE 0.7
Spark plug cover VX XE (homemade) 0.1
Speedometer instrument, cable and drive 0.71
Spring, rear, De dion long progressive type 1.65
Spring, rear, De dion short type 180lb 1.7
Steering lock, bolts and key 0.76
Sump Caterham Wet sump 5.7
Sump Dry QED pan and Caterham pump inc hoses drive pulley, belt, 7lt tank 7.35
Tax disk holder (ali) 0.08
Tax disk holder (Carbon fibre) and nylon screws. 0.02
Throttle bodies (DCOE, inc inlet manifold, linkage, ITG air filter) 4.4
Throttle cable (webers) 0.09
Tonneau cover both sides 1.4
Tool roll 3
Tow rope 0.7
Tunnel cover (homemade) 0.6
Tunnel cover Caterham Ali / Leather 1.2
Undertray covers front and half sump (ali) 0.70
Vecta immobiliser 0.45
Washer bottle bracket 0.08
Washer bottle inc usual water 0.6
Washer pump 0.12
Water hoses. VX black rubber u tube 0.35
Water hoses. VX black rubber top hose 0.5
Water hoses. VX black rubber bottom 'S' hose 0.3
Water hoses. VX Silicone u tube 0.18
Water hoses. VX Silicone top hose 0.3
Water hoses. VX Silicone Bottom 'S' hose 0.2
Wheel nuts (19mm Caterham standard closed) x 16 0.85
Wheel nuts (22mm race) 0.9
Wheel studs standard length x 16 0.48
Wheel studs standard race length 0.64
Wing front 13-14" GRP Short 0.68
Wing front 13-14" Carbon 0.40
Wing front cycle bracket 1.07
Wing front flared inc bolts ?
Wing rear GRP 1.45
Wing rear stone guard Stainless steel 0.55
Wiper assembly 2
Quite interesting reading. Unless you start with a K series you'd have to spend a small fortune trying to get the weight down to even be level pegging...
I have some Westfield-specific weights listed on my website.
-John
Westfield supplied heater I took off my car weighed 4.1kg (dry), heater duct moulding thing was 0.4kg..
Ahhh, but what about the saving in the water the rad contained   ;) and the 4 bolts/nuts and washers holing it in?.;)  ;)  ;)
The lists are VV interesting actually and show where the big savings can be made. I have to ask tho do the small savings, 100g here and there really matter in a road car?
I'll do some calcs later and see whether the cost in saving 10-15Kgs in weight would outweigh cost of upping the engine a few BHP to get the same power to weight..... unless someone has already done it????
Stuart ;)  ;)  ;)  ;)
That's why I quoted weight as dry...  :p  ;):D
Don't forget to offset the weight of the bolts with the weight of the GRP that you drill out of the scuttle... :):D  :p
DRY   AHHHHHH   I thought you meant you weren't drunk when you weighed it
Does the SG of the battery count   :p  :p
:D  :D  :D  :D  :D  :D  :D  :D  :D  :D  :D
Take 2 identical Westys (if there were such a thing), strip one of all the ****e to reduce weight, and up the BHP of the other so the power to weight ratio of the 2 cars end up the same. In theory at least, the Westy with the weight loss will have the biggest advantage, as not only do you gain acceleration, but also gain braking and cornering power too.
I know, it is a bit more complicated than that, but you get the idea.  :t-up:
Yep, all true  :D
I'm surprised some others' didn't bite at the challenge.  :D  :D
I'll have to loose a few pounds in weight coz I like to be moderately warm so theres no way I'm losing the heater. LOL
Stuart
