C20Xe Coscast Head - SBD Spec
Due to upgradeitis I have for sale
C20xe cylinder head (Coscast), mild / polished ports.
SBD 230BHP specification
Fitted with:-
Bronze valve guides
Wasted stem valves (Std sizes)
278 degree 11.78mm 105/3.46 mm SBD inlet camshaft
269 Degree 11.42 105 / 2.59mm SBD Exh Camshaft
SBD spring platforms
SBD double Springs
SBD Titanium caps
SBD Ultra light weight followers
Solid Shimmed & set up by SBD
SBD vernier pulleys (Early type)
Distributor Blank plate
Excellent condition & can be heard running as not removed from engine as yet.
Has done approx 7000 miles & 3 track days since build 2 yrs ago.
(pocketed pistons required !)
£1750 ono
Base map also available for MBE set up.
  • 3 months later...
Good afternoon
Is the head sold ??? If no... another question, Is the coscast head interchangeable with the "late" cylinder block?? Only to change the vernier pulleys and use the the "old" type cylinder head studs?? Can you eventually sdhip to Spain??
Trond
