Small headlights
Just ordered new small lights from M & P but only supplied with horizontal bolt for fitting.
Westfield standard headlamp bracket made for vertical bar underneath light to be bolted through the bracket.
What have other people used or have you made something up yourselves?    :durr:
thanks
J D      :cool:
???  ???  ???  ???  There's a horizontal bolt with which you can adjust headlight angle  ;)  and below this is a "vertical" fixing which can be secured to plate  :)  :)
Did you order correct ones ??? have they sent you the correct ones ??? have you a bit missing ???
Ordered same part number as on previous thread.
No they have not been delivered
and yes I have a part missing ??? but thats another story.
Made the mistake of asking M & P about the fixing so probably got the wrong info. :arse:
Thanks for your help.
Only need to make sure the Old Trout is not around when the delivery arrives.    :devil:
J D
They're actually bike lights and M&P deal with only bike stuff - so to be reasonable they would know too much about Westfields  ;)  ;)
Has your car already passed SVA  ???  ???  cos the lights won't  ;)  ;)  :(  :(  - so see if you can borrow a set for SVA purposes  :D  :D  and a "friendly" MOT tester helps  ;)  once a year  ;)  :)
Just upgrading 1997 Seiw ( everything ) so not involved with SVA.
What bulbs are best for these lights ???
Not a problem that I have. Absolutely not. I wear the trousers in our house. If the memsahib steps out of line then she gets reminded of who is boss around here pretty smartly.
However, just to ensure that someone is around to sign for the goods and for no other reason whatsoever, I do find that getting deliveries sent to work is useful.  :D
I take it that she does not have access to this site then?? :p  :p
The ones that come with the lights  :D  :D  ;)  ;)
Yes the bulbs supplied with the headlamos seem to work
Terry
And there was me thinking a 40 watt screw in would be OK
Many thanks for that piece of info. :sheep:
J D  :cool:
No. Policy decision. You know how it is with women  - don't want to fill their pretty little heads  with anything technical. And anyway she'd slaughter me if she copped some of this stuff...
:0
Ive got a pair of these to (M&P is only 20 mins away)
no problems with fitting at all and the mount is exactly where it should be (if they sent/you ordered the right ones)
Ive had both the bulbs that were supplied with the lights blow and damage the connector supplied (rewired to fireblade loom) both earth terminals overheated and broke away from the bulb (no it hasnt got a bad earth  :D ) I wouldnt use them again ...no probs since changing bulbs :D
theres a few pics Here so have a look as you can make out the mount on a couple of them
all the best
Trev :D
