Mazda 1.8 V6
Just been offered 1.8 V6 from a Mazda MX3 write off.
Probably around 40K miles.
Anybody used this engine or is this a non starter :sheep:
Have done a search and will wait for Blatman or Mr Stanton to assist ???
J D  :cool:
IMO a non-starter, if only because of complexity of installation. You will be 'on your own' sourcing induction/exhaust systems, and probably gearboxes/bell housings too. I dont think the engine makes a *huge* amount of power either.
Also, I have heard from a couple of sources that the 1.8 V6's are prone to self destructing, if the engine gets a thrash after it has been 'pootling' for a while. Apparently it is because the valve to piston clearences are extremely tight, and the build up of carbon on both can cause them to meet if it isnt thrashed on a regular basis-with messy consquences... :0
so that means a reasonably revvy and tourquey V6 that you'd have to thrash all the time  :(  ???  :)  :p  :t-up:
Wonder which car we could fit that into ???
Was offered gearbox and everything else off the car!  :cool:
A mate of mine bought one of these about 4 years ago and he still has it, its been reliable, but performance is naff i think.. 136ish BHP i think. (that reminds me, i am meant to be doing cam belt on it.. nice.........)
It would cost alot to convert in to Westy i would of thought but nothings impossible??
IIRC the 1.8 V6 comes out of the MX3, which is FWD. Did Mazda fit it to a RWD? ???
Sounds too complicated to fit in a Westy. ???
Will stick to Ford or VX  ( or Toyota )
J D  :cool:
Yep - as noted before you'd be on your own in sourcing parts and haveing one-off bits made  ;)  ;)  :(  :(  :(  :(
come on anything is possible  :t-up:
:0  :0  :0  :0  :0
i hope he never crashes it...
rover spent years trying to put the k series into mini, but every time they crash tested them the engine ended up in the cockpit... (well almost  :D )
