Norman Verona Posted November 24, 2011 Posted November 24, 2011 We are back in the house and it's lovely being warm and cosy. Lots of cosmetic jobs to do over the winter (such as painting and treating floors). The bad news (for me that is) is that I've torn my back muscles again. I did it about 6 weeks ago and have been pressing on with morphine and codeine (about 50% more than the suggested maximum) in order to complete the building work. I am know having physio twice a week and slowly reducing the pain killers. Also not doing any lifting, just pottering about doing small light work. However I do have a slight query. I do not want motion sensors on the proposed outside lights. I want to manually switch the lights on and have them stay on for a prescribed length of time. I have been sold an AEG VTR4 unit which is supposed to do this. The wiring diagram on the unit shows it wired with a dimmer unit. I have wired it as per the diagram but ignoring the dimmer and it doesn't work as it's supposed to. So, does anyone know a wiring diagram for this unit (it has an A1 and A2, 1 2 and 4 terminals) or does anyone know of a unit that can be energised and stay on for a prescribed period. I will be taking photos soon and will put the before and after on the web site. Cheers, Quote
peterg Posted November 24, 2011 Posted November 24, 2011 Never mind all that Norman, how's Lynne Sorry you've hurt your back again though Quote
Norman Verona Posted November 24, 2011 Author Posted November 24, 2011 Pete, she's getting better but it'll be months, if ever before she gets back to HER normal. She can almost walk normally but cannot stand in one position (she rocks like a weeble man) and she cannot bend down. But she can talk!!!!!! Quote
peterg Posted November 24, 2011 Posted November 24, 2011 Well, that's progress of a sort an good to hear it's in the right direction, thanks for the update Quote
Hammy Posted November 24, 2011 Posted November 24, 2011 Just found this..... looks a tad confusing but it might help soemone assist: VTR4 near end "stair case switches" I recon... Permanent Live supply to A2 and 1. Neutral to A1 From the old switch position: take wire from the switched side of lamp ( .i.e. side of the existing switch that goes to the lamp itself) and wire to 2 From the now empty hole in your switch wire to terminal 4 The other side of the existing light switch is the live feed and this can be looped across to A2 and 1. you now only need to find a neutral -from this circuit- to wire to terminal A1.( probably the hard bit!! -but by a bit of lateral thinking you might be able to mount the VTR4 near the light fitting itself, there's a neutral there , actually the best option if its a loop in system !! !) No responsibilty given or implied from this interpretation , make sure you agree first!!! or seek other help BTW the I guess the dimmer is to give you warning, if it was used on the stairs, that thel ight is about to go out!! Quote
Norman Verona Posted November 24, 2011 Author Posted November 24, 2011 Hammy, that diagram was the one I was using. However your suggestion is different to my interpretation. The unit fits in the consumer unit and will be fed by a 10 amp trip. The wires are already run down the outside wall to the lamp and switch. The switch is a momentary unit, is that what you expect? Many thanks, if it works there's a beer or 6 coming your way. We'll be in the UK from 17th to 27th December, if anyone wants to meet up for a beer. My "local" is Gardeners Rest in Neepsend (Sheffield) or Ladybower Inn at, er, Ladybower (on S.yorks/Derbyshire border) Quote
Man On The Clapham Omnibus Posted November 24, 2011 Posted November 24, 2011 Pete, she's getting better but it'll be months, if ever before she gets back to HER normal. She can almost walk normally but cannot stand in one position (she rocks like a weeble man) and she cannot bend down. But she can talk!!!!!! Good to hear Norman. Your long absences left me feeling nervous... Quote
Norman Verona Posted November 24, 2011 Author Posted November 24, 2011 Sorry Clive, I was a bit busy trying to beat the weather. As it happened the weather hasn't been a problem. Yesterday I was outside in a tee-shirt and it was warm! Anyway, she's on the mend and I've got back muscles to repair and then we'll be back to normal. Oh, apart from finding 2 brains. Quote
pistonbroke Posted November 25, 2011 Posted November 25, 2011 Sorry Clive, I was a bit busy trying to beat the weather. As it happened the weather hasn't been a problem. Yesterday I was outside in a tee-shirt and it was warm! Anyway, she's on the mend and I've got back muscles to repair and then we'll be back to normal. Oh, apart from finding 2 brains. Not "just" a T shirt we hope Quote
Hammy Posted November 25, 2011 Posted November 25, 2011 Hammy, that diagram was the one I was using. However your suggestion is different to my interpretation. The unit fits in the consumer unit and will be fed by a 10 amp trip. The wires are already run down the outside wall to the lamp and switch. The switch is a momentary unit, is that what you expect? Many thanks, if it works there's a beer or 6 coming your way. We'll be in the UK from 17th to 27th December, if anyone wants to meet up for a beer. My "local" is Gardeners Rest in Neepsend (Sheffield) or Ladybower Inn at, er, Ladybower (on S.yorks/Derbyshire border) Should work with momentary or otherwise. Check what I've said makes sense to you, covering bum here Quote
Norman Verona Posted November 25, 2011 Author Posted November 25, 2011 Bernie, of course, but it was a very long one. Quote
s2rrr Posted November 26, 2011 Posted November 26, 2011 They do a reasonable pub lunch in the Ladybower Inn, was in there a couple of months ago. Just an observation. Bob Quote
Norman Verona Posted November 27, 2011 Author Posted November 27, 2011 Bob, the landlady is a cordon-bleu cook and her meals are excellent. I used to live "round the corner" in Bradfield. I'm having a meal in there with friends and family just before Christmas to celebrate becoming an old codger officially.I'll be so much richer with my pension going into the bank. Ooops. just remembered it's a UK pension so may just buy me a pint or two a week. Quote
s2rrr Posted November 27, 2011 Posted November 27, 2011 Norman , Enjoy your meal, hope all your issues are well in hand and her maj is on the mend. Bob Quote
