non westfield car
Hi, my mate has got a Tiger 6......
The rear o/s brake cylinder was leaking, i replaced both sides and pads while i was doing the job.
I bleed the system, all ok, he's now since done a trackday etc, and got the problem again, the brake piping runs from the master cylinder into the rear o/s then routes out of there across the axle to the n/s.
should they be independantly fed?.
Or has anyone got any ideas how to cure the problem?
Cheers People
 :t-up:  ;)
No need to be ashamed Wookie  :blush:  :blush:  :D  :D  :devil: You're amongst "friends" here  :D  :devil:  :D  :devil:  :blush:  :blush:  :D
no, but when i built my super six the brake pipes ran from the m/c to the rear n/s then to the rear o/s but i cant see that making any difference.
adam
nope honest guv, its not mine............   :arse:  :arse: anyone got any clues to the problem?
It may be coincidence, it maybe a defective cylinder, or you might have excessive heat build up in that drum, which has destroyed the seals. Try and assertain what has actually caused the problem when the job is done again. look for foreign matter in the cylinder (swarf etc), overheating of seals, scoring of cylinder bores, that type of thing.
The plumbing arrangement sounds correct for a live axle, it is the same as the majority of live axled Fords....   ;)
