godsy1969 Posted November 19, 2011 Posted November 19, 2011 Unused MBE 992 with part complete loom was intending to use this as spark only for a carburretor engine so loom does need some finishing should you wish to run injection. Everything is here that you should need including spare pins, extra cable, USB lead and cable wrap for that finishing touch. Cable is Huber and Suhner and is top quality stuff. All the cables in place are sufficiently long and can be cut to length for your install. Also included are some rubber mounts. £300 the lot. Also for sale MBE985 mapping tool. Allows you to talk to the ECU via an OBD connector on the CAN link straight into your PC where you can run Easymap (downloadable from SBD web site). All pin outs and instructions can also be found on their web site. Mapping tool £75 MBE stuff Spare cable and wrap
