wizzer Posted November 17, 2011 Posted November 17, 2011 DeWalt DE9117 15min 7.2V - 18V Mains Battery Charger This is a 15 minutes charger for 7.2v up to 18.0 volt NiCd batteries (nickel cadmium). Can be used with the following batteries DE9057 DE9061 and DE9062. Voltage: 7.2-18.0 V Battery chemistry: NiCd Charging current: 7.5 A Charging Time: 15 (2.0 Ah) min Width: 166 mm Height: 83 mm Length: 181 mm Weight: 0.9 kg good condition fully working DeWalt DC981KA 12v XRP 13mm Heavy Duty Hammer Drill / Driver Powerful 12 Volt combination tool for heavy duty hammer-drilling and screwdriving applications. 22 position adjustable torque control for uniform results and optimised precision when screwdriving. Up to 45Nm of sustained torque for maximum performance. 13 mm single sleeve keyless chuck with automatic spindle lock for quick and easy bit change with one hand. Three speed settings for optimum performance in high torque, normal use and high speed applications. with one-hour charger, two batteries and heavy duty carrying case. Drill and batteries In very good condition, box and charger like new £130 plus delivery cheers t
