1558cc Hayabusa - approx 250 bhp and 145 ft-lb's
Proven performance in a front running hill climb single seater.
This engine has just completed one season hill climbing following full check and refresh by Extreme last winter.
Extreme Engines Specification:
Web Race Camshafts Extreme Spec
Web Heavy Duty valve springs & Titanium Valve retainers
One piece Steel Race Valves
Full Gas Flowed Cylinder Head
Cometic 83mm Cylinder head gasket
Extreme Custom Forged 83mm High Compression Ross Racing Pistons
Rebored & Replated 83mm Cylinder
Arrow steel H- Beam Stroker connecting Rods c/w ARP 625 Custom age rod bolts
Falicon Billet Steel 72mm stroker crankshaft
Falicon Billet clutch basket
Extreme Billet Starter & Idler cover c/w Limiter gear Kit
Heavy duty Output shaft
Extreme Clutch pawl set
Heavy Duty clutch springs
Heavy Duty gear change spring
Standard Hayabusa Gearbox
Price £8,750.00 (a considerable saving on the new build cost for one of these engines).
I think this would drop into mine quite nicely !
