Anyone know where I can get the above - I've tried the usual suspects but can't find a female rod end with an M10 x 1mm thread!
Have you tried McGill Motorsports, they do fine pitch versions of some of their metric rose joints. Though 1.0 mm is extra (damn) fine! 1.25 mm is the normal fine for an M10 isn't it?
Tried McGill Dave  :(
Yep - 1mm is damn fine pitch thread!
M10 Japanese bike Fine thread. Have you got space to use an M10 Male rod end with a double ended female bit that you could make up. The M10x1 taps are easy to get hold of.
Have you tried here?
Bearing-shop
Unfotunately Dave they're fine thread is the standard 1.25mm pitch  :(
There isn't a problem making an adaptor up - it's to screw onto the piston of  MX5 dampers to put into our new shock dyno; just thought it would be easier to buy a rod end if I could find one!
Ooh you have goodies already!  :t-up:  :t-up:  :t-up:
Last week or so went OK I take it?
If you need a hand or anything, you know you've only got to ask!
