Seiw
As above
Ive a 1990 seiw,early ind susp with a westfield / english diff
Looking for a cheap,used pair of rears
My ride is awfull - spring  adjusters were seized and now ive got the ride height ok theyre at max
Dont need anything fancy
Funds are tight as recently bought and ironing out other gremlins too
Ime in midlands but work all over or can arrange a courier
Steve
ive a set of rears if you need them clean could do with a paint up if your fussy were on my rolling chassis make me an offer on them will try and add a picture for you...
Hi Neo
They look identical to the ones i have on
Although my spring height rings had to be virtually melted with the oxy to get them to move and the damping adjuster doesnt seem to do anything
Being a newbie ive no idea what theyre worth,
I was hoping I could rely on seasoned westie owners to help me with that
You seem to pop up alot on here so i can only assume your one of the above !
They look clean and tidy enough,i assume everything works
What are the springs rated at, mine are wound right up to give a decent ride height, yours seem much lower on the thread
Let me know what you were hoping for,depending on where you are i can collect whenever convenient - otherwise i can arrange courier -save you the bother
Steve
Sorted :)
