2.0 XE Engine
2.0 XE 16V redtop.
Engine has ARP big end bolts and has had a rebore with standard pistons. Standard cams and valves, the head has been skimmed and some port work done.
4 bar hot oil pressure, new oil and water pumps, it has done 12k miles since the rebuild, mainly road miles with 3 or 4 track days. Doesn't use oil, doesn't overheat.
No ancilliaries. Standard sump. Showed 146bhp at the wheels on carbs on A&B's dyno.
Price £505.27p or very nearest offer.
John.
No, it doesn't have fuel injection or carbs.  :zzz:
No, it doesn't come with an exhaust manifold.  :down:
No, it doesn't have a flywheel, clutch, starter motor, radiator, oil cooler, alternator or ignition system.  :(
Yes, you will have to collect (from the Wirral).  :)
