Pantherman Posted September 1, 2011 Posted September 1, 2011 Neil. Further to your message and my email still interested in your parts. Can you please contact me. Thanks Dave
leeswesty Posted September 1, 2011 Posted September 1, 2011 Hi mate have you still got them shocks if so are they front or back or both and what condition if so and they are right length i will have them thanks lee
NDS Posted September 5, 2011 Author Posted September 5, 2011 UP DATED LIST: Front Alloy uprights (Westfield) with alloy hubs and new bearings £ 180SOLD Bodywork Main Tub SOLD Nose cone SOLD Bonnet SOLD Scuttle £30 Boot Box – Red £20 Front Wishbones new bushes and drop links £80 Rear Wishbones with new rose joints £140.00 Coil overs with springs Spaxs – Look new £150.00SOLD Rear Alloy Uprights with Drum Brakes ,Rear Drive shafts Rear Differential English with Westfield Alloy housing £300 Prop shaft Type 9 to English diff will check on length Exhaust Box Stainless steel - £40 Instruments VDO Speedo, Rev Counter, Fuel, Oil pressure £ 140 Fuel Tank (SEI) with sender and mounting straps £70SOLD Hand brake cable SOLD Wheels 14" Original Westfield £ 120 Wiring Harness /Westfield new labeled ready to fit. £ 120SOLD Front Cycle style wings and mounting brackets £ 70 Single roll loop £15 Pedal box - ex Cortina or similar -single master cylinder FREE TO A GOOD HOME! GRP (X 2) Seats with 3 point Williams harness for body cars £120 Cortina Alloy hubs – New with 45mm long studs with 12 x 1.5mm threads with 60 degree wheel nuts 19mmA/F NEW cost £62.00 each £80 for the pair SOLD Ralloy Dry sump tank – 6R4 type Ralloy part number RAL119 Length 20cm x Width 20cm height 41cm with screw top (cost £194.60) Used £105.00
Pantherman Posted September 5, 2011 Posted September 5, 2011 Neil . Intersted in the cycle wing brackets and possibly the cycle wings depending on size, I am running 185 /60 /13 . Will you split the brackets/ wings if necessary ? The seats are still listed , are they available ? Please let me know.
leeswesty Posted September 7, 2011 Posted September 7, 2011 Neil you are top man once again thanks for the parts they are spot on mate and a fast post time to lee.
