Westfield SE Chassis (1990)  Need blasting and powder coating / re panelling
Note: No V5. I think it was a race chassis. Its straight with no signs damage.
Front Alloy uprights with alloy hubs and new bearingsSOLD
Bodywork Main Tub SOLD
Nose cone
Bonnet
Scuttle
Wishbones with all track rod ends and drop links Blasted and painted Front Standard width
Rear
Coil overs  with springs Spaxs
Rear Alloy Uprights with Drum Brakes
Rear Drive shafts
Rear Differential  English with Westfield Alloy housing
Propshaft
Exhaust Box
Instruments VDO Speedo
Rev Counter
Fuel
Oil pressure
Fuel Tank with sender aero cap. ( single outlet and breather) SOLD
Rear Drums - New shoes
Hand brake cable
Drums
Wheels 14"
Westfield Harness / new labled ready to fit.SOLD
Front Mud guards and mounting brakets SOLD
Single roll loop SOLD
Pedal box - ex cortina or similar -single master cylinder
For sale complete £2290 or will break first week of September. I can arrange to have  the chassis blasted and powder coated locally at additional cost.
Neil
01738 550005
Hi neil
Just want to confirm you got my text re diff, wishbones znd shocks
Membership now through so can contact you here
Steve
Also emailed regarding uprights, hubs, gauges, wishbones (not desperate for those if the previous chap is) and wings.
Hi Neil,
What colour and condition is the Bodywork?
Can you e-mail me pics of the front alloy hubs and uprights. I am not sure what mine are so if you can send me a pic i'll see if they are the same.
Could also be interested in your rear drive shafts if you can send a pic, always worth it to have some spares!
send to
t_kirk1 (at) yahoo (dot ) com
Tim
PMs sent
Neil
Its rear wishbones i need Geoff
Fronts not needed
No pm received neil
hi Neil, Not sure if you got my email, I'm sure you are getting a lot of interest. Just want to confirm if you break the car I'm interested in the Zetec loom and the Dials.
All the best
Melvyn
19ac95- Steve
Tried to reply through the PM system.
I keep you posted
Regards
Neil
Ok neil
stevecoley1@fsmail.net if you cant
Steve. 19sac65
  • 3 weeks later...
Breaking the car/chassis
Front Alloy uprights (Westfield) with alloy hubs and new bearings £ 180SOLD
Nose cone SOLD
Bonnet SOLD
Scuttle  £30
Boot Box – Red  £20
Front Wishbones  new bushes and drop links  £80
Rear Wishbones  with new rose joints £140.00
Coil overs  with springs Spaxs – Look new   £150.00
Rear Alloy Uprights with Drum Brakes ,Rear Drive shafts  Rear Differential  English with Westfield  Alloy  housing  £300
Prop shaft  Type 9 to English diff will check on length
Exhaust Box  Stainless steel - £40
Instruments VDO Speedo, Rev Counter, Fuel, Oil pressure £ 140
Fuel Tank (SEI)  with sender and mounting straps  £70
Hand brake cable SOLD
Wheels 14" Original Westfield  £ 120
Wiring Harness /Westfield new labeled ready to fit. £ 120 SOLD
Front Cycle style wings and mounting brackets £ 70SOLD
Single roll loop  £15SOLD
Pedal box - ex Cortina or similar -single master cylinder FREE TO A GOOD HOME!
GRP (X 2) Seats with 3 point Williams harness for body cars £120SOLD
Cortina Alloy hubs – New with 45mm long studs with 12 x 1.5mm threads with 60 degree wheel nuts 19mmA/F NEW cost £62.00  each   £80 for the pair SOLD
Ralloy Dry sump tank – 6R4 type   Ralloy part number RAL119 Length 20cm x
Width 20cm height 41cm with screw top (cost £194.60) Used    £105.00
Delivery up to 30kg  £12.50 UK full track and trace
This chassis is available but has proved bent have been quoted £800 to repair but its still for sale should anyone want it. £300
I can forward photos of the parts etc . I have no idea how to post them on the boardroom. Drop me a mail and I will forward them.
Neil
From flyingbanana in the Chat area:
"I am still unable to PM or post in the For Sale section, but I paid up on 2nd August, Cubs Honour.
Anybody willing to post in there for me re. the seats- Narrow or Wide body? Any chance of a piccy?
Thanks FB"
Payment sent... front uprights, hubs & bearings.
Geoff - that was quick!
Will forward the tracking number tomorow.
Neil
