kirkyboy5 Posted August 5, 2011 Posted August 5, 2011 Hi, Today whilst driving the westie I stopped at traffic lights and noticed it was very difficult to get it into 1st. So hard infact that I resulted in putting it into 2nd just to pull away from the lights. I noticed its quite difficult to get it into reverse also and makes little 'clunk' when enganging in reverse. This seems to only happen when the motor is up to temp, any ideas??? Thanks Dan Quote
Captain Colonial Posted August 6, 2011 Posted August 6, 2011 As in how high up is the clutch pedal when it bites? Quote
kirkyboy5 Posted August 6, 2011 Author Posted August 6, 2011 tHe clutch pedal seems fine to me and the biting point is pretty normal really :/ Dan Quote
kirkyboy5 Posted August 6, 2011 Author Posted August 6, 2011 do you think its worth running into westfield and seeing if they can find out whats wrong with them? Dan Quote
perksy Posted August 6, 2011 Posted August 6, 2011 What engine & gearbox combination are you using Quote
kirkyboy5 Posted August 7, 2011 Author Posted August 7, 2011 Iv got a pinto in it with a type 9 gear box dan Quote
SteveD Posted August 7, 2011 Posted August 7, 2011 haveyou got a westy extension on the box ,if so check that Quote
kirkyboy5 Posted August 7, 2011 Author Posted August 7, 2011 Sorry lads, havnt a clue how to check if I have or not ! If I have how can I adjust it?? Thanks dan Quote
SteveD Posted August 7, 2011 Posted August 7, 2011 take off the gear lever gator and see if the lever goes onto a metal plate or onto the alloy gearbox , remove the three bolts holding the lever in place and check the plastic clip on shim is in place they have been known to dissintigrate and give the symtoms you describe with and without the extension Quote
kirkyboy5 Posted August 7, 2011 Author Posted August 7, 2011 ohh brill mate, will try this when the rain stops (if it ever does) Thanks kidda Dan Quote
