jay.perry Posted August 3, 2011 Posted August 3, 2011 Hi guys dont know if there is any one on here but i'm after the reset code for my alarm. After a few burgularies in the area i decided to swap the sensors in the garage as they didn't seem as sensative as they used to be, however the alarm will not set now. I think it is because the tamper function has been activated and needs to be reset. its a guardtec 300 series. Ive had a quick look on the net but for obvious reasons the code cannot be found!! Thanks in advance Jay Quote
carpetstu Posted August 3, 2011 Posted August 3, 2011 usually the reset code is the same as your 4 digit entry code. It might want the main fuse pulling inside the box and resetting that way. My system throws a wobbly sometimes and it cures it. Some info here on operational controls http://www.ukpanels.com/downloa....ser.pdf Some more info here http://www.howtomendit.com/answers.php?id=124499 If you get stuck I know an alarm engineer you could call for some advice on resetting with alarm engineers codes if he will give them over Quote
jay.perry Posted August 3, 2011 Author Posted August 3, 2011 Thanks Stu, will have a play around tomorrow, bit late now to be upsetting the neighbours!! Quote
Rich8977 Posted August 6, 2011 Posted August 6, 2011 Jay Have you sorted the issue out with your alarm? if not let me know i am in the trade. Regards Rich Quote
jay.perry Posted August 6, 2011 Author Posted August 6, 2011 Hi Rich, i think i've sorted it, seems to be working ok now. Thanks anyway,Jay Quote
