SEiGHT 2007 5ltr V8
Mark Williamson
FOR SALE. 2007 Westfield 5 Litre  Rover V8- SOLD
Built by Barry Ashcroft and Steve Maund February – June 2007, MoT to June 2012, Taxed till Oct 2011.
The current mileage is 6900.
The V8 Developments engine has 320bhp and 350lbs of torque, this is one of the fastest  road kit cars around.  When I bought the car from Steve in May 2009 he handed me the build receipts, which totaled nearly £30,000.00, the engine and gearbox alone cost £11.5k the specification is endless but please see below for the main points:
Exterior;
Black FW Bodywork, V8 Bonnet, (with added ventilation holes) and V8 Nosecone.
Carbon Mods, carbon rear arch protectors and CSR style carbon cycle wings and door sills
LED rear lights
LED front side lights
RAC Roll Bar
Bespoke Luggage Rack
Westfield Doors
Bespoke Half Doors
Perspex Wind Deflectors
Half Hood
Gun Metal Gray Viper Stripes
Range Rover HST Side Air Vents
Suspension and Wheels;
Nitron’s with Team Dynamics Pro Race 1.2’s, Toyo 888’s 205/50/15 front and 225/50/15’s rear.
Interior;
Carbon Dash
Digi Dash Lite Dash, shows the following information;
Programmable Speed Display
Programmable RPM Display
Diesel Engine Compatible
Programmable Shift Lights
Engaged Gear (Calculation Based)
Coolant Temperature
Oil Temperature
Oil Pressure
Fuel Level
Engine Hour Counter
Real time clock on board (Date & Time)
Acceleration / Deceleration Timers
Road Legal non-resettable Odometer
Trip Distance Timer, Counter and Average Speed Calculator
5 Key Warning Lights
1 Configurable Warning Light
6 Programmable Warning Alarms
MPH / Km/h selectable speed
Display units in °C/°F/PSI/BAR
Latitude & Longitude
Altitude
Heading
GPS speed
UTC Date & Time
GPS Lap timing via GPS position
Traffic Camera Type
Camera Speed Limit
Programmable Alert in Metres to camera
Pre-loaded with over 10,000 UK camera locations, this will be updated before the sale.
Switches for;
Lights
Heater Fan
Cooling Fan Override
Wipers
Hazards
Horn
Removable Momo flat bottomed 270mm steering wheel (prewired for switches on wheel)
JK Composites Carbon headrest seats with padding
Leather handbrake and gear gaitor.
Lowered Westfield Floor
Engine built by V8 Developments
Top Hat liner cylinder block at 96mm nominal bore – cross bolted with 4 bolt mains
lightened and balanced Crankshaft – 86.36mm special grind
I-Beam Steel Rods – lightened and balanced
HyperEutectic pistons – lightened and balanced with valve relief
Stage IV Ultimate Fast Road Cylinder Heads – with double valve springs and late type stem seals
Polished and ported inlet manifold – 45mm and port matched.
45mm aluminium trumpet base – shortened radiused trumpets and ported housing
Balanced set of injectors
ACT Carbon Plenum Chamber with 71mm Throttle Body
V8Developments Stealth Camshaft – excellent fast road cam specially ground by Kent Cams
Hi Rev lifters
Vernier timing chain set – infinitely adjustable with a double roller timing chain
Complete valve train and rocker assemblies
Shortened Baffled sump designed for Westfield use.
Lightened and balanced flywheel
High Performance Motorsport clutch
R380 Gearbox
Bell Housing
Gearbox Remote
Lightened and balanced front pulley and damper
Oil cooler kit – 13 row with hoses and connectors
Late type ‘serpentine’ front cover and oil pump
Complete engine loom and ECU
Tornado ECU Chip Upgrade
Stainless Steel Exhaust Headers and manifolds
Gear Reduction Starter Motor
High Output Alternator
Mallory Electronic Ignition and distributor
Morosso Plug Leads
NGK Spark Plugs
High Performance Aluminium Radiator – designed for Westfield
Kenlowe 16 inch Fan
Shroud for radiator
This is a great car which is one of the quickest on the road today.
Priced to sell at £15,995.00
Private Registration Number W7 FLD INCLUDED in sale
Call Mark on 07776160583
Here are a few snaps.....
More pictures can be found at -
My Webpage
Thanks for looking  :cool:
Mark
Link to comment
For anyone looking for a road going ballistic but compliant car this is a bargain!
I have been a passenger and can say it is seriously quick and handles fantastic
Good luck with the sale
Link to comment
Dogs gonads  :D superb car  ;)  ;) good luck with the sale Mark  :)
Link to comment
one of the best thats come up for sale in a long time.
Link to comment
If I had the money I would buy that back from you.
Good luck with the sale, make sure it goes to a good home.
Steve
Link to comment
If you decide to break it put me down for the rear stone guards :devil:  :devil:    :p
cracking car at a fraction of the build costs
Link to comment
I think it's too good to break Stu, LOL.
Thanks for the interest, maybe Santa will bring you some nice carbon guards like mine? :D
Mark
Link to comment
Mark
You have to be a good boy for Santa to call. That's Stu out then ;)
Link to comment
lol pasty muncher
whats next mark........back to racing a bec ;)  :laugh:
Link to comment
QUOTE
Stu, I plan to paint the garage floor while thinking about my next move :t-up:
I've updated the Ad, more photo's can be found here-
My Webpage
Link to comment
That's one hell of a car your letting go Mark, good luck with the sale  :t-up:
Link to comment
