NDS Posted June 6, 2011 Posted June 6, 2011 Cortina Alloy hubs – New with 45mm long studs with 12 x 1.5mm threads with 60 degree wheel nuts 19mmA/F NEW cost £62.00 each £80 for the pair Ralloy Dry sump tank – 6R4 type Ralloy part number RAL119 Length 20cm x Width 20cm hight 41cm with screw top (cost £194.60) Used £105.00 The dry sump tank fits between the chassis rails of an SE unfortunately not with the engine in place! Can deliver by TNT Neil Tel 01738 55005
ivormole Posted June 6, 2011 Posted June 6, 2011 Hi Neil Interested in the pair of hubs, what make are they and do they include bearings and grease covers? Are they used or brand new ? Does the £80 incl p&p ? Any chance of a couple of pics to: markgrinnell@btinternet.com Sorry for all the questions ! Thanks Mark
NDS Posted June 6, 2011 Author Posted June 6, 2011 Yes they are brand new. A few marks from the press when I fitted the studs. sorry no bearings . The photos will follow shortly. Regards Neil
NDS Posted June 20, 2011 Author Posted June 20, 2011 Andy, have you received my PMs? Please can you contact me 01738 550005 Neil
