David H Posted June 3, 2011 Posted June 3, 2011 For Sale, updated list Westfield tool kit. Opened once £25 Full set of blue Willans harnesses. Push button and come with shoulder pads. Used. £150 new, £80 Cobra Roadster 7 seats. These come with harness slots in yellow and blue. Very good condition. Over £500new, £180 for both 280mm lightweight radiator fan part no. 2611009 only used for testing so as new. £85 new, £45 Wilwood smart pads for Powerlight calipers, nearly new, £25 Wilwood Poly A pads. Brand new in box £40 Westfield alloy rear uprights, hubs and driveshafts for sierra diff. Low mileage and all good condition. Offers, but don’t forget how expensive this lot is new. 2 x Rear Avo adjustable dampers 2.25” with springs 175lbs. May need recon as uncertain of age £50 SOLD MT75 Gearbox also in excellent condition, 8,000 miles since recon, spot on gear change. Includes cable clutch lever and pivot, £70 Chards one off custom prop shaft for Type9 to Sierra Diff specially made for the type9 conversion on an MT75 chassis. Built for 300 bhp. Lovely bit of kit and hardly used. £140 Chards one off custom propshaft, Ford Type 9 to Subaru diff, £120 SPA mirror in black for drivers side only £15 Bosch 701 Beige injectors x 4. (I upgraded) Work perfectly and have been flow tested. £50 2 x VDO water senders 3/8 as new £10 each. Westfield standard steering rack mounting kit £35 new, £15 KAAZ LSD, freshly rebuilt (this is for a Subaru diff) currently built as a 4.1 r160 diff. £400. Bargain Subaru Impreza r160 driveshafts in good condition, £80 Sierra 3.62 diff (open) and case in pieces. Low mileage and in fine condition. (LSD taken out for my other diff. This one just needs putting back together £70 Westfield spare tyre holder and plate backing with light to mount to rear of chassis £10 2x Zetec engine mount rubbers £10 Westfield Handbrake cable including divider £15 Zetec Silvertop crankcase breather system one way valve converted to 2 way £10 Twin air horns and compressor. One horn cracked. £7 Zetec 2.0 cam cover painted red. One side has chipped paint otherwise spot on. Comes with gasket, £20 Westfield aluminium side panels with blue vinyl good condition £20 Westfield aluminium indicator pods. No lenses One has a scratch, will polish out £94 new, £30 Westfield aluminium pedal box cover £8 Westfield Chrome yellow fillet £20 Westfield Chrome yellow 1998 scuttle with the rounded lip. They don’t make these anymore holes for screen and aeroscreen. £40 2 x Westfield Chrome yellow bonnets; one almost new with a very tidy hole cut for Jenvey throttle bodies with Pipercross filter. This was on a Zetec mt75 chassis. £110 One with a not so tidy hole. £50
westy turbo Posted June 3, 2011 Posted June 3, 2011 Are the upper and lower front wishbones wide track?
tkm_dave Posted June 3, 2011 Posted June 3, 2011 Interested in the tyres (potentially all 4), you have a PM
David H Posted June 3, 2011 Author Posted June 3, 2011 Are the upper and lower front wishbones wide track? no standard
David H Posted June 3, 2011 Author Posted June 3, 2011 Thanks for the pms so far I will reply to all asap Dave
Trojan Posted June 3, 2011 Posted June 3, 2011 I am interested in the Cortina uprights, do you have a PM?
jonclancy Posted June 3, 2011 Posted June 3, 2011 Hi Dave, PM sent ref the boot box and carbon cover... Thanks! Jon
