Will this filler cap fit?
anyone know wether this will fit? My plastic Rover one is looking a little tired and this looks the dogs IMHO.
link here
Greg
That is exactly the same one as I have fitted. The only issue for you would be the size of the existing hole in your bodywork. You can use some flexible pipe to join up with the tank behind.
Dave O.
Greg,
I have fitted this filler cap:
It is a standard Westfield item. If I look closely at your pictures I think that the filler cap in your pictures is not designed to accept a (big) hose on the rear, but is supposed to be bolted to a flange. The one I have is designed to accept a hose:
Hope this helps
Also looks identical to the one on mine, only mine has the aero style spring loaded flap for the nozzle and breather holes around the edge
the official westie one is £93 + VAT + postage  :0
I think Merlin sell them...not sure about price, but probably cheaper than Westfield.
Andy
This link should take you straight to filler caps.....
I was just looking for the right page when the boss walked in... :D
Figured the home page link would suffice!
Andy
I was just being a smart A***.............
Besides, one upmanship is a good game. especially when I'm not a computer pro, and you are....... :p  :p  :D  :D
Taxi.............. :devil:
Pah...you were lucky...this time...  :angry:
Andy
I have similar on mine. I had to order some spare keys, so I phoned up Westfield and was told that they get the filler caps from a company called Newton Equipment. Their address is
Ajax Works,
Hertford road,
Barking,
Essex,
IG11 8DY.
Do you have the fuel cap that is inset into the bodywork?
If so, then it may not. Or at least, not quite so easily.....  ???
