tommy holly Posted May 29, 2011 Posted May 29, 2011 hi whats the differance between sew and seiw is it independent suspension if so can a sew be change to a seiw Cheers Tommy Quote
Mark Stanton Posted May 29, 2011 Posted May 29, 2011 An SEiw is a wide body independent suspension An SEw is a wide body with a solid rear axle (not that many around) and in answer to you last question simple answer = No (at least not without building a new rear end) Quote
tommy holly Posted May 29, 2011 Author Posted May 29, 2011 Thanks now i understand Cheers Tommy Quote
chazpowerslide Posted May 29, 2011 Posted May 29, 2011 Nowt wrong with the live axle cars. Chaz. Quote
Mark Stanton Posted May 29, 2011 Posted May 29, 2011 no-one said there was however betcha someone does now Quote
fatbaldbloke Posted May 29, 2011 Posted May 29, 2011 however betcha someone does now Not me. I like live axle cars. Easy to set up and less to wear. Quote
markcoopers Posted June 2, 2011 Posted June 2, 2011 I did have a SEW once, but that one no longer exists. Quote
chazpowerslide Posted June 3, 2011 Posted June 3, 2011 Kinda went in spectacular style did it not Mark? Chaz. Quote
markcoopers Posted June 4, 2011 Posted June 4, 2011 Chassis beyond use is i think the technical term Quote
