Clutch cable
Had this since I first built the car, but between collecting the kit from the factory and building it, I changed to a hydraulic clutch set up. So this has never even been on the car!  :oops:
Clicky
do you know if it would fit the C20XE to type 9 box? Just put my re-built engine in at the weekend and the clutch cable is looking a little tired.
Tim
Funnily enough, it's an XE engine with a Type 9 box that the kit was spec'd for, so Westfield supplied XE suitable bits.
Pmd you as I need one urgently as mine snapped this morning.... after the alternator packed up and so had to get a new one... and on of the oil pipes split... not a great day!!
Hi Mike, it's yours, PM'd and posted IYSWIM  :t-up:
Fingers crossed you get everything sorted.
