adam1330 Posted May 2, 2011 Posted May 2, 2011 Plenty of pics for all below here: here Pair of Westfield cycle wings in Bright Blue. In generally good condition, Some small hairline cracks around one of the mounting holes, and one hole is a bit big from where I had to drill out a bolt. There is a chunk missing from the lip on the front of one, although you can hardly see this when they are in place, and also the side of one needs a polish. £50 Collection preferred, although could work out postage if needed. Vinyl covered dash --SOLD-- Cut for a standard set of VDO gauges, plus a hole where my immobiliser was fitted. Couple of marks as can be seen in photos, plus the vinyl needs re-sticking along the bottom edge. --SOLD-- £25 +P&P Carbon effect headlamp bowls Fantastic condition, came off a very low milage 2 year old car. Purchased off a friend for the lens to put in my existing bowls. Paint has chipped off slightly around the edge of one bezel, as can be seen in photo(see link at top of ad). If you want, I'll throw in the old corroded lenses I took out of mine at no extra charge. £60 +P&P If you want higher res images, let me know.
