David H Posted April 30, 2011 Posted April 30, 2011 For Sale Westfield tool kit. Opened once £25 Full set of blue Willans harnesses. Push button and come with shoulder pads. Used. £150 new, £80 Cobra Roadster 7 seats. These come with harness slots in yellow and blue. Very good condition. Over £500new, £180 for both 280mm Westfield lightweight radiator fan part no. 2611009 only used for testing so as new. £85 new, £45 Wilwood smart pads for Powerlight calipers, nearly new, £25 Wilwood Poly A pads. Brand new in box £40. These pads are awesome and my number 1 choice for a Westfield. MT75 Gearbox also in excellent condition, 8,000 miles since recon, spot on gear change. Includes cable clutch lever and pivot, £70 Chards one off custom prop shaft for Type9 to Sierra Diff specially made for the type9 conversion on an MT75 chassis. Built for 300 bhp. Lovely bit of kit and hardly used. £140 Chards one off custom propshaft, Ford Type 9 to Subaru diff, £120 SPA mirror in black for drivers side only £15 Bosch 701 Beige injectors x 4. (I upgraded) Work perfectly and have been flow tested. £50 2 x VDO water senders 3/8 as new £10 each. Westfield standard steering rack mounting kit £35 new, £15 KAAZ LSD, freshly rebuilt (this is for a Subaru diff) currently built as a 4.1 r160 diff. £400. Bargain Subaru Impreza r160 driveshafts in good condition, £80 Sierra 3.62 diff (open) and case in pieces. Low mileage and in fine condition. (LSD taken out for my other diff. This one just needs putting back together £70 2x Zetec engine mount rubbers £10 Custom air separator for Ford performance. Aluminium. Takes breather from crank and cam cover, you can then put it back to the sump or collect it in a catch can. £30 Zetec Silvertop crankcase breather system one way valve converted to 2 way £10 Twin air horns and compressor. One horn cracked. £7 Zetec 2.0 cam cover painted red. One side has chipped paint otherwise spot on. Comes with gasket, £20 Westfield aluminium side panels with blue vinyl good condition £20 Westfield aluminium pedal box cover £8 Westfield Chrome yellow fillet £20 Westfield Chrome yellow 1998 scuttle with the rounded lip. They don’t make these anymore holes for screen and aeroscreen. £40 2 x Westfield Chrome yellow bonnets; one almost new with a very tidy hole cut for Jenvey throttle bodies with Pipercross filter. This was on a Zetec mt75 chassis. £110 One with a not so tidy hole. £50 Playskool narrow body rear anti roll bar kit. Unused. £140 Westfield nose cone in Electric Blue. This has a black ring sprayed onto the front. Condition used but good. £100 BMW e46 M3, K&N Gen II cold air induction kit. £130 Pagid RS29 pads for front. Only used for a short while but upgraded to big brakes before they got much use. £120 Postage not included.
uk89camaro Posted April 30, 2011 Posted April 30, 2011 Interested in the Westfield tool kit, what's actually in it? Paul
Johnson Posted April 30, 2011 Posted April 30, 2011 Interested in the RadTec radiator is it the direct replacement one for a polo rad? Will have it if it is Thanks
David H Posted April 30, 2011 Author Posted April 30, 2011 Interested in the Westfield tool kit, what's actually in it? Paul http://www.westfield-sportscars.co.uk/shop....T_ID=80
RedditchJay Posted April 30, 2011 Posted April 30, 2011 any pics of the trailer ? single axles or twin axles ?
dave_t Posted April 30, 2011 Posted April 30, 2011 Interested in the plug cover and car cover. Will send a PM.
Tango Squadon Posted April 30, 2011 Posted April 30, 2011 First dibs on the Protech dampers please! PM sent.
uk89camaro Posted April 30, 2011 Posted April 30, 2011 Interested in the Westfield tool kit, what's actually in it? Paul http://www.westfield-sportscars.co.uk/shop....T_ID=80 ah ok. No good to me as I don't carry a spare.
phil h Posted April 30, 2011 Posted April 30, 2011 can you post a picture of the boot box cover please.i have a long range tank boot box will it fit i am very interested and will be at stoneliegh on monday maybe i could try it ? thanks
David H Posted April 30, 2011 Author Posted April 30, 2011 any pics of the trailer ? single axles or twin axles ? Trailer is a single axle non fancy hardcore fully functioning trailer with no frills. Hence the price. Got to be honest, I am moving house at the moment and don't have a lot of time. The trailer is great especially for the money. Pictures of everything will take time to materialise and I'm getting many items sold without having to take loads. If I struggle to sell anything i will post pictures, please understand I am not trying to be rude!
David H Posted April 30, 2011 Author Posted April 30, 2011 can you post a picture of the boot box cover please.i have a long range tank boot box will it fit i am very interested and will be at stoneliegh on monday maybe i could try it ? thanks I will bring it to stoneleigh but only if it doesn't sell first. First to commit to buying it will have it. It is split into three sections so the underneath can be got at. Beautifully cut. You cant fit it unless you take the rear bars out of your roll bar though.
David H Posted April 30, 2011 Author Posted April 30, 2011 Pms replied to. I understand everyone wants to see pictures. There's no point in asking for a picture of a wishbone chaps. I am limited for time so if you are really serious about buying an item I will be making a special journey to the storage to take photos etc. I am moving house so its hectic.
