For sale is the Westfield I have always wanted unfortunately I cannot get along with the car. After numerous days out I just can’t get used to the bike engine and clutch. Further to this I am looking to travel Europe in the summer and fancy doing so in a little more comfort.  This is the third Westfield I have owned and comprises of a great specification as follows: -
Westfield Megabusa,
Mot’d to October 2011
Taxed to end of January 2012
Engine
Rebuilt (2007 less than 1000 miles ago)
Extreme Hayabusa Engine 1396cc upgraded engine
Internal Crankcase porting
Balanced and shot peened conrods
Lightened, knife edged polished and balanced crank
Gas Flowed Cylinder Head
Vernier Cam Sprockets
High Compression pistons 84mm
Race Camshafts
Power Commander
Electric water pump
Cam chain and cam chain tension recall kit fitted
Extreme engines dry sump kit.
Large setrab oil cooler
Repackable silencer made by precision engineering one od the quietest available for the hayabusa
Recently rolling roaded at Z cars 188 BHP@ 11533 rpm / 137 Nm @ 8477 @ the wheels.
Although the specification has many race derived parts the car and engine combination is no more difficult to drive than a standard bike engined car but in some aspect’s could be considered better has the torque has increased. The oil has always been changed regularly with a recent major service being completed by Z cars consisting of oil and filter change, spark plugs, fuel filter diff fluid change, chassis optimisation including adding additional braces to increase the strength and rigidity. Within the service the gear linkage was also examined and optimised the clutch was stripped, inspected, cleaned and refitted and the starter motor was also given the same treatment.
Drivetrain and Clutch
Heavy duty clutch springs fitted
New clutch pawls fitted
Billet clutch slave cylinder
Extreme engines high ratio gearbox fitted.
High ratio 3rd and 4th double gear input
High ratio 5th gear input
High ratio 6th gear input
Freelander differential with quaife ATB internals.
Trickshifter pro fitted with paddle shift allowing full clutchless up and downshifts.
Westfield reverse gearbox fitted.
Body / Chassis
Year of chassis manufacture: 2002
Wide bodied independent rear suspension chassis with chassis strengthening completed by Z cars.
Detachable Rear arches.
Carbon effect Rear arch protectors.
Yellow body with black arches and nosecone (best colour in my opinion).
Westfield aeroscreen
Full 'Caged' roll cage, FIA approved
Carbon boot box cover
20 litre Westfield fuel tank
Steering and suspension
Quick rack
Widetrack Suspension
Upgraded protech shocks and corner weighted
Front and rear anti roll bars
Westfield alloy front uprights
Westfield alloy rear uprights
13” Minilite wheels with Avon CR28 tire’s 205/60/R13. Tires are relatively new with 4-5mm of tread.
Brakes
Westfield Hi-spec alloy front calipers.
Floor mounted pedal box
Interior
Omex Shift Lights
Geartronics Gear indicator
Race Tech Steering wheel with removable boss
Westfield padded race seat with harnesses
FIA cut out switch.
Westfield gauges
- Oil temperature & Pressure
- Water temperature
- Rev Counter
- Speedometer
- Fuel Gauge
Lightweight battery.
File of paperwork, invoices, receipts.
£10,495
If you would like any further information/ photos then please don’t hesitate to ask.
Ross
Mob: 07506694928
Tel: 0191 2818448
Email: rossmurray123 at hotmail.com ( replace at with@)
  • 2 weeks later...
Sold
