novarally Posted April 18, 2011 Posted April 18, 2011 I'VE DECIDED TO SELL MY LOVELY LITTLE BRIAN JAMES MINNO SHUTTLE 4 WHEEL TRAILER. IT HAS AN INTERNAL WHHEL/TYRE RACK AND INTERNALLY STORED 2m LONG RAMPS. IT IS FULLY LOCKABLE AND ALL THE LIGHTS WORK. THIS HAD ALL THE EXTRAS FROM NEW; LONGER RAMPS, WINCH, HEAVY DUTY JOCKEY WHEEL, SPARE WHEEL, TYRE RACK AND BRIAN JAMES WHEEL CLAMP (attaches to the wheel studs). THE MINNO SHUTTLE TRAILER IS VERY SOUGHT AFTER, IT HAS A UNIQUE SPLIT BODY DESIGN MAKING LOADING VERY EASY. AND OF COURSE IT DOUBLES AS A SHELTER FROM WIND AND RAIN! THE MINNO TOWS EXTREMELY WELL ALLOWING YOU TO TRANSPORT YOUR VEHICLE EASILY TO EVENTS KEEPING THEM CLEAN AND DRY, WITH THE ADDED PEACE OF MIND THAT YOUR CAR CAN BE SECURELY LOCKED UP OVERNIGHT AT AN EVENT IF NECESSARY. THIS TRAILER HAS BEEN WELL LOOKED AFTER. QUOTE FROM ABOUT TRAILERS "Stylish, compact and yet practical fully enclosed small car transporter. The entire package is compact enough to make storage of the trailer inside a standard single car garage possible. The Minno Shuttle is a well-established part of the Brian James Trailers family. Purpose designed to provide you with all of the benefits of a fully-enclosed trailer, without being any larger than is necessary, the Minno Shuttle features a unique split body design. The benefit is full access into the trailer, allowing cars to be driven into and out of the trailer. Ideal for Caterham 7’s, Minis, historic racers, vintage and veteran cars. • Ultra-compact design with small frontal area • Smooth, aerodynamic gel coat GRP finish • Steel reinforced structure provides maximum durability • Closed, sealed and locked in seconds Innovative body system gives you excellent practicality and great styling, all designed to fully protect your car" General Specifications • Spare wheel • Multi-hole tie-down facility • 50mm ball coupling head with integral lock • Fully enclosed GRP body with split-body design and gas spring lift assist Rear lamps fully protected. • Stable with low centre of gravity • Heavy Duty jockey wheel • Front access door (locking) • Adjustable wheel stop chocks • Fully hot-dip galvanised steel chassis • Centre deck • Winch 1 gear manual Internal tyre rack (not currently fitted) Internal light Proper Brian James wheel lock Technical Specifications • Gross capacity 1380Kg • Load capacity 800Kg • Load bed length 11ft (3.0m) • Load bed width 5ft 5ins (1.65m) • Overall trailer length 15ft (4.57m) • Overall trailer width 6ft 8ins (2.03m) • Overall height 5ft 9ins (1.75m) • Internal height 4ft 7ins (1.40m) £3250 Please e-mail me at; colinesmith@aol.com
novarally Posted April 21, 2011 Author Posted April 21, 2011 Now sold, many thanks for all the interest.
