Help Clegg with Smeg
just paid 50 odd quid to have our smeg oven cleaned
now when you turn the oven on it just keeps building heat and does not settle at the required level resulting in burnt food - eventually the oven gets so hot it just turns itself off
now I am quite used to this with Julies cooking but clearly there is a fault with the thermostat
I have tried turing the oven off at the wall -
any ideas? apart fro call an engineer out
call smeglington we had the same problem ,it was only a few quid
Mrs Cleggy to the boardroom please  :devil:
Perhaps Mothers day is the only time Cleggy uses the oven    :D
Don't be silly !
pfft the oven has been used to force dry various bits of car  :p
Not that familiar with smeg, but have see this happen to other blands.
Have seen thermostats and thermostatic controls play up after cleaning due to damp, crap etc, etc building up on them.
Single/double oven? Rotary controls or digital?
My suggestion would be find the thermostats, etc and make sure they are clean.
Failing that, call a 'one-man band' engineer, costs will be lower than the corporates etc.
Pretty sure the thermostat will be a capillary type with a metal 'bulb' tube in one of the sides of the oven. I'm afraid the cleaner has probably kinked the capillary when cleaning it.  It will be non repairable but relatively cheap to repair.  Try espares on line they have photos of parts so should be easily identified
Del
Are  you on a deathwish :bangshead:  :laugh:  :laugh:
Wot Del says.
Most ovens are dead easy to repair. Much easier than building or upgrading a Westy !
Mind you our Smeg Fridge/Freezer broke under warranty and it took Smeg UK six weeks to get anew compressor from Italy......
You lazy get £50 to clean the oven :0
Call a technician...
Well if you take the smeg out of the smeg how can it work? ???
Tubs
