Green is usually ign switched live, black is earth so the other must be the sender ?
Thanks Hammy,
I will try it again. I think that problem could be in an inappropiate resistance from the level sender I have fitted. I will try with other models.
Anybody could tell me what's the stock sender from factory ?  (VDO ?......)
Javier
Is it working at all?  ie giving the wrong readings rather than not reading at all?
With a sender/gauge mismatch you will normally get some reading, even if it is inverted.
If it is not reading at all your first stop is a wiring problem.
black / green is sender
black to earth
green to switched ignition
guage uses a VDO sender if i remember rightly. i had one fitted - it was pants (sorry, but too inaccurate and the LED's fall out of the black plate they are fitted into - care required)
i would check your earths first - fuse ok?
Green/black to sender, black to earth and green to +
Empty tank........all leds on
Full tank............. all leds on
Green/black to + , black to earth and green to sender
Empty tank.........Just a green led on
Full tank.............Just  the same green led on
:0
I should replace my ATL sender. Probably the impedance is out of range.
:0
i would guess the impedence is not matching. sure they use VDO senders. i had the same led one and changed it to a racetech guage - had to swap the vdo to racetech
black / green is defo the signal wire
black - earth
green - power [switched via ignition - you dont want it on all the time or it will flatten battery]
Mmmm...thanks Tex.
I will try with a VDO unit.
