WIDGET Posted May 18, 2003 Posted May 18, 2003 I've the chance to buy an MT75 box for my SEIW which is running a 3.62 limited diff on 15" rims and when i get it a 2.0L Zetec with carbs. Can any one tell me if the gearbox that i need should come from any particular model? Quote
neilwillis Posted May 18, 2003 Posted May 18, 2003 Try and get one with a manual clutch. The best donor is I think a Twin Cam Sierra. At least, that's what mine came from. You might find a better choice would be a Type 9 box, it'll need a different bellhousing, but it'll fit an MT75 chassis cuz it's smaller. The advantage to a Type 9 is that you can change the ratios, and get stuff far cheaper than for an MT75. If I'd known sooner, I'd have opted for a Type 9 instead of the MT75, but c'est la vie. Quote
Westfieldman Posted May 18, 2003 Posted May 18, 2003 Type 9 as Blatters would say do a search its a no brainer Type 9 Type 9 Type 9 Type 9 Type 9 Type 9 Type 9 Type 9 Type 9 Type 9 Just in case blatters will be along soon to tell you its a type 9 you need. Paul. Quote
Blatman Posted May 18, 2003 Posted May 18, 2003 Type 9......... It's a no brainer, really....... Quote
