Polish mops / cutting paste
Grrrrrrrr
Just had my Golf drivin inside our warehouse to be worked on.... problem is the warehouse door has those heavy duty plastic strips..... end result is the car is covered in fairly deep scratches.....
Tried T cut wont even touch it so it will need a mop and paste.....
Do I buy a mop and paste ?  borrow one  or just pay someone circa £75 {local quote} to get it done.... I have used mops in the past {ex valeter when I was a teen} so have no issue using one and not burning through the paint.... etc etc
anyone tried any of the cheap n cheerful mops on the market ??  or got a reasonable one to loan ??
HELP......  :bangshead:  :bangshead:
Sorry to be the barer of bad news, if you can feel the scratches with your finger nail, its unlikely they will polish out.....
Russ
not quite as deep as finger nail but some are......  just got some slightly abrasive paste from Halfords so will have a go..... T cut wouldnt touch it...
Maybe your gypo neighbours scratched it??? As far as your insurance company is concerned, that is...!
hahaha.... just spent the last hour or so with the Meguiars Scratch X  2.0 and I must say its doing OK........ still got roof issues to get mopped BUT sides, boot etc etc pretty good from what it was looking like
Megs G220 and Menzerna Intensive is what you need on that. If I was closer I'd come across and do it
just bought some of this G3  rubbing compound to try next
UPOL 333 LIQUID CUTTING COMPOUND 250G (G3)
see if this will lift the deepest roof scratches...... still by hand though....
give me a bell wuv il talk you through what to do 07718992155 ,i have been doing bodywork 20 odd years  :bangshead:  :D you need to flat them not just buff em ,also depends on the colour to what you get away with and hide
steveD, should I get some wet n dry 3000 grade  ? ?
1200 and superfine flat the scratch with 1200 then sf  to get rid of the 1200 marks and sharpe edges of the scratch then buff it ,it takes practice wuv ,im willing to do it for you free of charge if you run it up to me  :oops:
ok.... i have some 1500 wetn dry and the Scratch X plus that 3G compound on ots way....so will try a small, light sample in a non obvious part and see how it goes... its a dark gray matalic so I am aware or assume the matalic paints are soft
failing that I work up in Cannock so only approx and hour from your neck of the woods...... give you a shout next week if i am stuck...
ok.... i have some 1500 so will try a small, light sample in a non obvious part and see how it goes... its a dark gray matalic so I am aware or assume the matalic paints are soft
not all wuv it depends on paint aswell ,give me a bell in the morning its easier to talk  :D
