Lundy Posted January 30, 2011 Share Posted January 30, 2011 Helix 7 1/4" (184mm) race clutch. Cover part number 63-211R (now 63-210R) which will handle 205ftlb of torque - more in a light car such as a Westfield/Caterham. Plate part number 56-1001 has 1" x 23 splines so suitable for a Ford gearbox. The unworn thickness of the plate is 7.2mm and I have measured today it at 6.99mm. The minimum thickness is 6.3mm so you can see that there is plenty of meat left on it. 7 ¼” (184mm) XE Flywheel skimmed and has the starter ring. All parts are in excellent condition and ready to go. £300 + postage I was going to convert my X-Flow to dry sump but I have now changed the engine to an XE so I have the following for sale. X-Flow dry sump has some dents and marks but is water tight, included also is a Burton Power Products bottom end gasket set. £85 + post X-Flow Cosworth 5 port dry sump pump. £75 + post Westfield exhaust part No. 1712001 F2 HB (Not re-packable) only fitted to an engine for 10mins but I decided it was too much work to get it to fit my narrow body. £100 + post Westfield Narrow body seats with adjustable runners. Small tear on driver’s seat and slight marks around head rest mount a patch on passenger seat which does not show when fitted. They have only done 1500 miles since being fitted and the passenger seat has hardly been sat in. Also available if required are some head restraints that I made up in order to pass the IVA. . First picture is from a Westfield brochure. £100 + post Westfield standard chromed roll over bar, slight corrosion in the chrome around the mounting plate, free to anyone who wants to put it to good use. Driveshaft fitted to a narrowbody with a 2000E box to an escort live axle 700mm in length good condition £50 + post All parts can be collect from just outside Chelmsford. Any questions please ask Chris Link to comment Share on other sites More sharing options...
