o/t ultrasonic welding
Haha sorry mate, didn't mean to come off as arrogant then, just generally curious cause I've seen a couple different questions from you regarding these disc things :)
I have nothing of use to add to the topic of ultrasonic welding lol, i know how to use a normal welder that you hold in your hand, and I seen a Plasma welder in action :cool: on my work experience, but that's the limit of my welding experience :D
Ultrasonic welding between two plastic components will use a sacrificial localised t*t [1](proper engineering term) :laugh:  to provide the material for the weld itself.
Instances where I've experienced usage of it in vehicles aren't subject to the v.tight tolerances I imagine you are talking about.
It's quite comonly used in IP's (instrument panels) in cars and often with ducts/vents made from multi-part mouldings....
Not saying it can't be done with ultrasonics but IME of it's more generalised application, it won't give you a super low tolerance joint......
HTH
[1]New strapline for Bob perhaps?
My other toy has sacrificial t**s.... :D
edit:Quick process overview Here
