Vauxhall Red top clear out
Vauxhall redtop parts:
Vauxhall 2 litre Engine (Non Cocast) head inc Starter, Alternator on Caterham mounting with single V belt new HP oil pump and Filter blanking plate with -8 fittings (Oil pump blanking plug for remote filter and front cover cost £475.00) - no sump £450.00
Vauxhall 2litre Engine Less inlet/exhaust manifold ex Calibra , Inc starter, alternator coil packs, on poly v belt standard.injectors Standard sump. £300.00
Vauxhall Block – Bare used for mocking up £50.00
Vauxhall Crank – standard (pistons and rods available if required). £50.00
Vauxhall Red Top Engine mounts, with HD mounts £55.00
Vauxhall SBD 100mm sump and oil pick up pipe £125.00 SOLD
Westfield Exhaust manifold low exit. £120
Titan dry sump kit complete, Scavenge pump. Front cover, Mounting plate Toothed belt, Crank pulley, Sump,  Test fitted to engine only £650.00
SBD Ford type 9 bell housing £130
Westfield Exhaust manifold low exit. £120 ( no digs but used)
Ford Type 9 with Caterham stick extension and rose jointed £150.00
Ford Type 9 standard Steel belhousing- £100.00
Can arrange delivery by DHL prefer collection
Neil
01738 550005 Perth UK.
did you get my pm re: engine mounts? first dibs pls
First dibs on dry sump please, do you know how old it is and if the pump has had the mod?
Regards
PM sent re Westfield XE manifold.
  • 2 weeks later...
Not sure if PMs are getting through so e-mail address is:
barry@datapro.gotadsl.co.uk
For pictures of Westfield low exit manifold
  • 1 year later...
Just on the off chance wondering if the XE to type 9 bellhousing might still be kicking around, engine mounts for that matter too? Dom
