MartyD Posted November 22, 2010 Posted November 22, 2010 Hi All Just purchased my first Westfield Huyabusa powered!! It has a Westfield reverse box How does this work?? I mean how are you supposed to find REVERSE??? Do they need any upkeep? Thanks Marty D Quote
Terry Everall Posted November 22, 2010 Posted November 22, 2010 Push the small lever forward and you have 6 reverse gears Quote
JeffC Posted November 22, 2010 Posted November 22, 2010 and if it wont go in let the car roll forward or backwards that should help it mesh in.. yep loads of maintainence, they p*ss oil out, the bolts vibrate out, the oil seals go, flange nuts come undone.. welcome to the world of bec Quote
MartyD Posted November 23, 2010 Author Posted November 23, 2010 Thanks Car is on stands at mo and dosent seem to want to go in Probibley best to wait to back on the ground with engine running? Going to be a whole lot more questions im sure P.S is there a reverse light sensor on the gearbox? Marty D Quote
Blatman Posted November 23, 2010 Posted November 23, 2010 Just turn the rear wheels. It'll slot in... Quote
MartyD Posted November 23, 2010 Author Posted November 23, 2010 Ill Try that, the lever seems rather tight(Hope it isnt broken) Has anyone had similer feelings? Marty D Quote
kev91 Posted November 24, 2010 Posted November 24, 2010 hello, I have just got a Megablade myself, I find that there isnt much play in the lever at all, I find to get in reverse, with engine running, put into first gear and put a little pressure onto reverse lever and bring the clutch up gentally as drive begins to turn it will go in. kev Quote
tex Posted November 24, 2010 Posted November 24, 2010 Ill Try that, the lever seems rather tight(Hope it isnt broken) Has anyone had similer feelings? Marty D if it feels tight you could check the linkages for free play. The bushes should be really free moving with little wobble. Bit of oil should help. If the cars on stands it might be a good idea to use the time to make life easier for yourself in the future by making the side panels around the box not riveted on. Drill the rivets out and pop some rivnuts in thier place. M5 stainless cap head bolts. Maybe a spring washer to help stop them vibrating loose. It will help later on when maintenance is needed. Quote
MartyD Posted November 24, 2010 Author Posted November 24, 2010 Thanks lads all good advice Will try at the weekend Marty D Quote
