USB Serial adapters
Get one with an FTDI chip.. this is what most ECU manufactures recommend and causes less issues with progs written for old serial ports.
CJ
Get what with a FTDI Chipset, the cable, the card, or replacement hard drive!!!!!!
Or buy a cheap old laptop that has a serial port?
Dell D400's good for this. Nice and small and plenty available for less than £100 on ebay.
Thats how I got the Lenovo ;)
my billinton usb serial i use for a few diagnostics.. so far no probs on an old xp machine.
- had better try it on a windows 7 notebook just in case now..
( as mentioned - you need to use the same usb socket to keep the com port the same, or it'll give a new com number and you might need to either get into control panel/system to move it, or reset all the software settings for each of the programs that'll use it.)
ps we use it on webasto/wabco - and on a temp "blackbox" for freight. - and on the megasquirt of course :-D )
CJ
Topic is USB to serial adapters lol !
CJ
  • 5 years later...
I bought this: http://www.ebay.co.uk/itm/351766162399?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT and installed it under Windows 10. I also downloaded and installed the free VirtualBox and then set up a Windows XP virtual machine. Then I installed the Prolific drivers on the WinXP VM. I plugged the USB to Serial converter in and set the drivers advanced setting to COM1 on both Win10 and WinXP. I then plugged it into my Dunnell ECU and ran up UCAMS 1.24 and it only works! :)
  • Like 3
Holy thread resurrection...
I use usb to serial converters for work (like Andy I suspect) and they are often pressed in to service for ECU's etc.
This one linked to below works with everything, and I mean everything I have thrown at it. DTA's for sure, the rest I can't remember but betwen my brother and I we have been through Emerald, Omex, Megasquirt (euw...) and something in an Aston N23 GT4 that needed a good coat of looking at.
https://www.amazon.co.uk/Keyspan-High-speed-Serial-Adapter-230kbps/dp/B0000VYJRY/ref=sr_1_1?s=computers&ie=UTF8&qid=1471564817&sr=1-1&keywords=keyspan+usb+serial+adapter
Bookmarked for future use...
I knew you'd know where I was coming from with that ;)
Buy one :d
