gixermark Posted November 4, 2010 Posted November 4, 2010 hi Guys, have tried the search to no avail... I'm after the width of an SEI with the wide/extended rear arches used for 10" rear wheels... More specifically, does anyone know if they fit into the std minno sized trailer ?? (5Ft 5") Thanks, Mark Quote
Bananaman Posted November 4, 2010 Posted November 4, 2010 hi Guys, have tried the search to no avail... I'm after the width of an SEI with the wide/extended rear arches used for 10" rear wheels... More specifically, does anyone know if they fit into the std minno sized trailer ?? (5Ft 5") Thanks, Mark No they wont fit, you need a 6' wide trailer really although people have modded the minno at the back to make it fit!! Quote
gixermark Posted November 4, 2010 Author Posted November 4, 2010 thanks... not really an option to mod mine (easily) as its one of the fiberglass covered jobs... Quote
Cam Posted November 4, 2010 Posted November 4, 2010 Mark Mine was the same width as a Minnow and I had to mod it so my car with extra wides would fit. Details here Cheers Quote
gixermark Posted November 4, 2010 Author Posted November 4, 2010 thanks Cam.. just looking at your avtar - were you at the birkett in a yellow westy !! ? is so small world - i was over chatting to you for a few minutes - bloke with strange (irish) accent Quote
Kevin Jones Posted November 4, 2010 Posted November 4, 2010 I put smaller rears on mine for transport, the arches then go over the top of the trailer side rails, also added 1" boards to help lift the rear a bit to aid arch clearance. Cheap solution for uncovered, but if your fiberglass is tight to the side rails it may be too tight. Quote
gixermark Posted November 4, 2010 Author Posted November 4, 2010 thanks Kevin - whats the actual width of the car with these arches fitted then ? There woudl be some room inside the trailer over the actual bed width... but very little Quote
Kevin Jones Posted November 5, 2010 Posted November 5, 2010 It's 5' 8", so I have ~1" on each side above the side rails. If you look down from above the edge of each arch aligns to outer edge of the trailer almost exactly. The front of the arch (where you fit a protector) is slightly wider than the rear, maybe 1/4" difference. Quote
Cam Posted November 5, 2010 Posted November 5, 2010 thanks Cam.. just looking at your avtar - were you at the birkett in a yellow westy !! ? is so small world - i was over chatting to you for a few minutes - bloke with strange (irish) accent Yes Mark that was me Quote
gixermark Posted November 5, 2010 Author Posted November 5, 2010 thought so Cam - car sounded lovely by the way Thanks for that Kevin.... Quote
