stephenh Posted October 14, 2010 Posted October 14, 2010 Moss grows in moist shady conditions - therefore remove moisture and shade Yes, chop all the trees and shrubs down. Quote
stephenh Posted October 14, 2010 Posted October 14, 2010 Sodium Hypochlorite is used to disinfect swimming pools and even pipes and vessels in the food and drinks industries I believe. A friend of mine buys it without difficulty to use in his swimming pool. It does create hydrochloric acid, and releases oxygen, when diluted with water (which is why it so effective as a steralising agent) so you would need to use it very dilute I should think or it would burn any grass or plants next to the drive. Quote
Paul Hurdsfield - Joint Manchester AO Posted October 14, 2010 Posted October 14, 2010 Moss grows in moist shady conditions - therefore remove moisture and shade Yes, chop all the trees and shrubs down. Nah, put an Easyup over it and hang a sun lamp from it Quote
Mark Stanton Posted October 14, 2010 Posted October 14, 2010 Trees will be of use for log burner and are a renewable energy source Quote
Paul Edden Posted October 14, 2010 Author Posted October 14, 2010 Moss grows in moist shady conditions - therefore remove moisture and shade Come on ex 'el presidentee - you've been to my gaff - chop all the trees down - how long have you got!!!! Quote
blitz Posted October 15, 2010 Posted October 15, 2010 I have exactly the same problem, made worse because the trees are Limes that spew Sugar solution in huge qauntities all summer, this feeds the moss and turns the cars black. It also atracts Wasps, sometimes the car is alive with them. Unfortunatly the trees belong to the Highways Dept. and they won't reduce the size of them. They are massive, higher than my three story house and they bury us with various things, starting with what appears to be tobacco in the spring, then cases off the buds, then HUGE amounts of leaves, so many that if I sweep them out into the road, they amount to drifts 3 foot high, half the width of the road and 20 feet long. Every gap on the cars fills up with this crap, which gets wet and rots, it's a nightmare. If I cut them down the fine would ruin me. B$%&*$%*S Rant over. Quote
Blatman Posted October 16, 2010 Posted October 16, 2010 I have exactly the same problem, made worse because the trees are Limes that spew Sugar solution in huge qauntities all summer, this feeds the moss and turns the cars black. It also atracts Wasps, sometimes the car is alive with them. Unfortunatly the trees belong to the Highways Dept. and they won't reduce the size of them. They are massive, higher than my three story house and they bury us with various things, starting with what appears to be tobacco in the spring, then cases off the buds, then HUGE amounts of leaves, so many that if I sweep them out into the road, they amount to drifts 3 foot high, half the width of the road and 20 feet long. Every gap on the cars fills up with this crap, which gets wet and rots, it's a nightmare. If I cut them down the fine would ruin me. B$%&*$%*S Rant over. I thought it was legal to remove any overhanging branches from a "neighbours" tree. If the Highways Agency aren't being good neighbours, report them to the council like you would any other troublesome neighbour, listing your grievances and what you consider a reasonable solution... Quote
