s2k7 Posted September 28, 2010 Posted September 28, 2010 Anyone knows if there is someone selling a pre-cut stone guard 3m protection film design for Westfield? Similar: http://tinyurl.com/34ewlbc Quote
perksy Posted September 28, 2010 Posted September 28, 2010 I bought a Roll of the protection film off ebay and cut it to suit (made some templates up first using newspaper) Used it to cover my Westfield arch protectors Think it was the same stuff the TVR lads use to protect theirs from stone chips Quote
s2k7 Posted September 28, 2010 Author Posted September 28, 2010 Did you use a hair dryer to make it stick or just water and sponges? I want to use in the rear cycle fender (stone guard) instead of the metal stone guard from westfield. I'm worried it might not stick in the corner lip. Thanks Perksy Quote
perksy Posted September 28, 2010 Posted September 28, 2010 Did you use a hair dryer to make it stick or just water and sponges? I want to use in the rear cycle fender (stone guard) instead of the metal stone guard from westfield. I'm worried it might not stick in the corner lip. Thanks Perksy Used Water applied by a Hand sprayer and then a credit card & soft cloth to remove any bubbles from under the film Make sure its nice & clean under the film Didn't wrap it right around the radius's on the arches Tried to keep the shapes fairly flat/straight, otherwise it can start to get abit tricky Quote
s2k7 Posted September 28, 2010 Author Posted September 28, 2010 Awesome Smokey!!! thanks Persky thank you again----I will attempt but if it don't work, I will go with smokey's route. Quote
