Alloy sump XE
As above standard alloy sump so I can cut away the area around the drain plug and weld to my damaged sump.
Might consider similar from any other sump for ford /vauxhall just so i can reuse the drain plug bit.
thx
I have a spare, I has a hole in but will be perfect for your needs. Am in Basingstoke hampshire, is that close enough to you?
As per my PM this is a 270 mile round trip, very much appreciate the offer, I'll see if anything else shows up.
Anyone in the Midlands ??
thanks
Now hopefully sorted - thx for the help and offers
