Exhaust mounting
After finally getting the exhaust manifold through the hole and mounting it on the side of the engine, I have carried on an put on the rear exhaust mounting.
However there is a bit of a discrepency between the end of the exhaust and the mount.  About 1.5" in fact.
Looking at it I need to cut 1.5" off of the end of the manifold tube so that the silencer will slide on correctly.  Before I make the cut, can anybody else tell me if they have had to make this kind of adjustment or if there is something that I should look out for? ???
oilman i had to do yhe same, mine was about that as well inch and a half or so, better longer than shorter though :D
Great.  I couldn't see that there would be a problem but not a bad idea to ask.
