Clutch Release Bearing perhaps?
I have an annoying squeak when the car is cold, if I depress the clutch it vanishes, but returns when I release the clutch.
Do you think that the clutch release bearing is worn?
Hi Brucester70
I've had this problem on a Zetec Car with MT75 gearbox, it got progressively worse untill it stranded me in Wales :arse:
I belive it is a common problem on these cars.
Andy :t-up:
Brucester70> sounds like you'll be ok unless you go to Wales ;)
What engine/box have you got? Not that it makes much difference but would help to guage how big a job it is
Si
I am running a VX 2l with a standard Type 9, what do you think then?
Sounds like it could be the release bearing but could also be something as simple as a build up of old oil on the bearing face. Has it been stood for any lenght of time or has it been in the damp?
Mine does it on the green car. I'll be fixing it just after it falls apart........
FWIW, many years ago, my parents had a car which did this (A Triumph Herald, IIRC). It lasted for years..............YMMV.
