remote solenoid
i have just finished fitting new loom, and just wanted
confirmation that the solenoid is wired up the correct way,
as i have no diagram to work from.  :arse:
            i think its a austin item, car is a 91 SE .1700 xflow
On the l/h there is one bolt and two spades, to which i have
put main +feed ,alternator and +battery lead.
In the centre is one spade, soleniod to ignition switch.
On the r/h there is one bolt ,which has starter motor lead.
could someone please confirm wether this is connected the
right way round or not,  as i dont want it going up in flames :blush:
cheers in advance
rob
wheres the earth wire connected?
The large bolt terminals sound ok, battery feed, alternator feed and 12v take off for ignition & aux. all onto one side of large terminals. Starter motor lead to other large terminal.
Are there any markings / numbers around the spade terminals?
Normally you have a 12v feed from the ignition switch when in the start position and on the opposing spade connector an earth, so when you turn the key it operates the switch/solenoid and basically connects the two large terminals together.
Is one of the left hand spades connected to the large terminal?
 Ign....... .                      .....Earth
              .  Bat +
              . Alt/aux    s/m .
hi paul
the solenoid is earthed by its fixing bracket to the chassis.
                 live ign feed
                      --l--------------------
                      l                               l
                      l                               l
                      l +to bat               s/moto
                      l   O                      O  l
                      l                               l
                      l................................
                         l             l
               alternator         solenoid wire
                                        to ignition
the live and alternator spades run through the casing with the
bolt coming through the centre, hope this explains things
better than first post :blush:
so is this correct? ???
cheers rob
