Gauging interest- toyota 4 AG-E/gearbox and lots o
Now then, now then.... due to a change in direction this will need to go after Mid October. This is intended to be a drop in package
Will be looking to sell as a package preferably or might split if no interest. Gauging interest within the club before going on pistonheads
1587 cc toyota 4AG-E engine- approx 160 ish bhp
Fresh this season with
New rings, shells and mains/ARP rod bolts- Supercharged crank
Gary goodyear ported/skimmed head Compression ratio 12:1.
kent cams with alloy verniers
kent cam belt
New oil pump/water pump
Currently on new 45's on my own manifold, but would match up to throttle bodies with a manifold that I have which is matched to the head
Currently running on ignition only Emerald ECU which is also available as well as the loom
Helix alloy flywheel and cerametalic sprung clutch plate/ HD cover
Steel exhaust manifold 4-1 and collector- probably wunoff silencer box also
Currently on steel shortened sump but have a High capacity low level one off alloy sump
A whole load of spares-Supercharged crank/starters/alternators/clutch/oil pumps/watrepumps/ timing belts x2.
Another head with Piper 300 cams and TRD undercap shims. Set of home made verniers.
Spare rods/pistons. 1 standard head/loads of valves
I'll need to do an audit of spares - sure there is more!
Facet fuel pump red top x 2
Also have gearbox- Type 9 SCCR with tran-x gearkit. Rebuilt last year with new bearings & baulk rings
Toyota bellhousing to fit above
English CWP 4.7 ratio
English CWP 4.4 ratio
narrow SE windscreen and pillars
2x toyos- 205/45/15- 4mm
4 x 195/45/15 stunners -5mm plus
Basically, I need to clear from mid October and would rather offer to club members initially but do need sensible offers. Give me a call to discuss - Ta tim 07841828382  :D
you have pm
shakey you have pm
QUOTE
Are you planniong on going in reverse then mate?  :p
A seriously good package for someone wanting to swap to a full ready to go 16v package without spending a fortune. Give the man a call..........
Going to play with the BEC boys Tim?
What finish is on the windscreen pillars please?
Pillars currently smooth  and sprayed satin black to match the screen   :cool:
you never quite know what ur gonna get........life is like a box of chocs!
could be fun!
Thanks for responding, not quite what I wanted though, sorry! Good luck with the sale!
  • 3 weeks later...
"High capacity low level one off alloy sump"
Is it still available? Any idea of a price? I PM'd you but had no response yet. :)
Thanks,
Dave
Tim is getting married today and will no doubt then be a way for a few days on honeymoon so bear with him
yeh anglesey next weekend :D
