Bananaman Posted September 8, 2010 Posted September 8, 2010 Alloy/Aeroquip JIC -10 bits 5no. 90deg Bends £12.00 each 1No. Swivel End £6.00 4No. End finishers (Jubilee Clip) £2.50 each 1No. Male/Male connector (44mm long) £3.00 1No. Male/Male connector (67mm long) £3.50 1No. Female/Female connector £4.50 1No. -10 to-16 Reducer Male/Male £3.50 JIC -12 3No. Swivel End £6.50 each 4No. End finishers (Jubilee Clip) £3.00 each JIC -16 4No. End finishers (Jubilee Clip) £2.50each (Also reducer -10 to -16 as above) JIC -20 4No. End finishers (Jubilee Clip) £3.00 each Brass Connectors JIC -10 2No. Male/Male connector £2.50 each 2No. Female/Female connector £4.00 each 1No. Male/Female connector £2.50 1No. 90deg Male/Female £5.00 JIC -8 2No. Male/Male connector £2.50 each 1No. -8 to -16 Reducer £3.00 JIC -4 18No Nuts & Olives £5.00 the lot An assortment of Dowty Washers £7.50 the lot Plastic tool box with other bits & bobs… £12.50 the lot Or if you want to take the whole package £125.00 All +P&P (would be £10.00 for the lot!) or collect from Manchester! Andy 07776-147842
Timmay Zoom Zoom Posted September 13, 2010 Posted September 13, 2010 Does JIC fit BSP? if so do you know the equiverlent sizes? Not too sure of the sizes but are these Fuel line type sizes or are the oil line type sizes. What pipe diameters do the unions take, are they the easy fit ones? I could very well be inetersted if they are the oil ones for dry sumping as just had 2 of my pipes starting to leak. Cheers Tim
Simeon Posted September 13, 2010 Posted September 13, 2010 JIC is different to BSP but you can get adaptors.
Bananaman Posted September 18, 2010 Author Posted September 18, 2010 BUMP These end tomorrow morning on e-bay at 9.55 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110584045465
